.NET
Active Contributor
0 Kudos
Post 1 of 9
ads_queueexp
1051 Views, 8 Replies
04-20-2012 03:02 AM
Hi there,
Does anyone know how to get “ads_queueexpr” to work under AutoCAD 2013?
Private Declare Auto Function ads_queueexpr Lib "acad.exe" (ByVal strExpr As String) As Integer
ads_queueexpr("(command""_dtext"" p1 8 0)")
I asked ADN and they said it's now part of "accore.dll"
But I'm still not sure how to reference it.
Martin.
http://www.designprosoftware.co.uk/
Imports System
Imports System.Text
Imports System.Runtime.InteropServices
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
<Assembly: CommandClass(GetType(AutoCAD_VB_plug_in1.MyCommands))>
Namespace AutoCAD_VB_plug_in1
Public Class MyCommands
<DllImport("accore.dll", CharSet:=CharSet.Ansi, CallingConvention:=CallingConvention.Cdecl, EntryPoint:="ads_queueexpr")>
Public Shared Function ads_queueexpr(command As Byte()) As Integer
End Function
<CommandMethod("MyGroup", "MyCommand", "MyCommandLocal", CommandFlags.Modal)> _
Public Sub MyCommand() ' This method can have any name
Dim uEncode As UnicodeEncoding = New UnicodeEncoding
Call ads_queueexpr(uEncode.GetBytes( _
"(command " + Chr(34) + "_ZOOM" + Chr(34) + " " + Chr(34) + "_Extents" + Chr(34) + ")"))
End Sub
End Class
End Namespace
1,210 Kudos
Post 2 of 9
Re: ads_queueexp
04-20-2012 03:24 AM in reply to: DesignProQuig
change the read part (if you are speaking about AutoCAD 2013)
Private Declare Auto Function ads_queueexpr Lib "accore.dll" (ByVal strExpr As String) As Integer
- alfred -
Alfred NESWADBA
Active Contributor
0 Kudos
Post 3 of 9
Re: ads_queueexp
04-20-2012 03:31 AM in reply to: Alfred.NESWADBA
I feel a little silly for not spotting that ;-).  Thanks for the help.
That has helpped, it now sort of works but now I receive this error:
A call to PInvoke function <Mydll>::ads_queueexpr' has unbalanced the stack. This is likely because the managed PInvoke signature does not match the unmanaged target signature. Check that the calling convention and parameters of the PInvoke signature match the target unmanaged signature.
ADN sent me this code in C#, I write only in VB.net & cou;dn't onvert using one of the on-line converters:
using System.Text;
[DllImport("accore.dll", CharSet = CharSet.Ansi, CallingConvention = CallingConvention.Cdecl, EntryPoint = "ads_queueexpr")]
extern static int ads_queueexpr(byte[] command);
UnicodeEncoding uEncode = new UnicodeEncoding();
ads_queueexpr(uEncode.GetBytes("(Command \"StartOverrule\")"));
Chers,
Martin.
Moderator
277 Kudos
Post 4 of 9
Re: ads_queueexp
04-20-2012 06:41 AM in reply to: DesignProQuig
Imports System
Imports System.Text
        End Function
        End Sub
    End Class
End Namespace
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Active Contributor
0 Kudos
Post 5 of 9
Re: ads_queueexp
04-20-2012 07:29 AM in reply to: Alexander.Rivilis
Thank you very much for the help everyone, ;-).
Martin.
Moderator
277 Kudos
Post 6 of 9
Re: ads_queueexp
04-20-2012 07:38 AM in reply to: DesignProQuig
Martin.
Kudos and Accepted Solutions will be helpful. ;-)
Active Contributor
0 Kudos
Post 7 of 9
Re: ads_queueexp
04-20-2012 07:48 AM in reply to: Alexander.Rivilis
LOL, Done! :smileyvery-happy:
ADN Support Specialist
67 Kudos
Post 8 of 9
Re: ads_queueexp
04-20-2012 04:49 PM in reply to: DesignProQuig
Hi Martin,
An alternative to ads_queueexpr for running a command at startup - http://adndevblog.typepad.com/autocad/2012/04/autoloader-the-startupcommand-parameter.html.
BTW If you asked this question through ADN support, whoever answered you should have made sure you understood the specific changes required to your code. If you send me a private message with the Case number, I'll check the casenotes and 'educate' :smileywink: whoever answered you.
Cheers,
Stephen Preston
Autodesk Developer Network
Active Contributor
0 Kudos
Post 9 of 9
Re: ads_queueexp
04-21-2012 03:28 AM in reply to: StephenPreston
Hi Stephen,
I did get an answer and it was perfect.  I was flapping because it was getting close to 5pm, and I didn't know if I would get my answer for the weekend.  So no need to put the smack down. ;-).
Martin.
