.NET
Adjust attribute text width
2 REPLIES 2
ditran7577
1934 Views, 2 Replies
Hi All,
Is there any way to adjust width of attribute text so that it is not out of contained block. The attribute is set at left alignment and width factor <=1. Please see picture below:
Thanks so much.
2 REPLIES 2
norman.yuan
in reply to: ditran7577
You need to find out the attribte text's width, and then you need to find out the allowed/desired width. Once you get these 2 widths, you can calculate the WidthFactor of AttributeReference.
I put together some quick code that does it:
using System;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
[assembly: CommandClass(typeof(AttributeWidthFactor.MyCommands))]
namespace AttributeWidthFactor
    public class MyCommands
        [CommandMethod("AttWidth")]
        public static void SetAttrWidthFactor()
            Document dwg = Application.DocumentManager.MdiActiveDocument;
            Editor ed = dwg.Editor;
            //Pick an attributereference in a block
            PromptNestedEntityOptions opt = new
                PromptNestedEntityOptions("\nPick an attribute:");
            PromptNestedEntityResult res = ed.GetNestedEntity(opt);
            if (res.Status == PromptStatus.OK)
                if (res.ObjectId.ObjectClass.DxfName.ToUpper() == "ATTRIB")
                    //Ask user to pick a distance as desired width for
                    //the attribute to fit in. Based on the block, the width
                    //could be a known value
                    PromptPointOptions popt = new
                        PromptPointOptions("\nPick width base point:");
                    PromptPointResult pres = ed.GetPoint(popt);
                    if (pres.Status != PromptStatus.OK) return;
                    Point3d basePt = pres.Value;
                    PromptDistanceOptions dopt =
                        new PromptDistanceOptions("\nPick width: ");
                    dopt.UseBasePoint = true;
                    dopt.BasePoint = basePt;
                    PromptDoubleResult dres = ed.GetDistance(dopt);
                    if (dres.Status != PromptStatus.OK) return;
                    //This is the width we want to fit the attribute text's width
                    double w = dres.Value;
                    using (Transaction tran =
                        dwg.TransactionManager.StartTransaction())
                        AttributeReference att = (AttributeReference)tran.GetObject(
                            res.ObjectId, OpenMode.ForWrite);
                        //Get attribute's width, assuming it is placed horizontally
                        double aw = Math.Abs(att.GeometricExtents.MaxPoint.X
                            - att.GeometricExtents.MinPoint.X);
                        //This is the WidthFactor
                        double factor = w / aw;
                        att.WidthFactor = factor;
                        tran.Commit();
                else
                    Application.ShowAlertDialog("Not an attribute!");
 The code will stretch or narrow the attribute to fit it into a given width.
HTH
ditran7577
Thanks a lot. It's OK.
”Boost
