.NET
.NET
Active Contributor
makepeace1
Message 1 of 3 (333 Views)
Adding trusted locations via DLL vb,net
333 Views, 2 Replies
04-15-2014 06:58 AM
I have got a lsp that add's the trusted location's to autocad if the version of autocad that is running is 2014 or above
(if (>= (getvar "ACADVER") "19.1")
(setvar "trustedpaths" (strcat (getvar "trustedpaths")
"c:\\folder1;"
"c:\\folder2;"
"c:\\folder3;"
"c:\\folder4;"
How would i be able to add that to my DLL to check if the trusted locations were already there if not to add them ?
Same method that we used for Support path.
 Public Sub gettrust()
Dim str_TR As String = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("TRUSTEDPATHS")
Dim C_Paths As String = LCase(str_TR)
Dim Old_Path_Ary As List(Of String) = New List(Of String)
Old_Path_Ary = C_Paths.Split(";").ToList
Dim New_paths As List(Of String) = New List(Of String)
New_paths.Add("C:\Program files\Folder1")
New_paths.Add("C:\Program files\Folder2")
New_paths.Add("C:\Program files\Folder3")
New_paths.Add("C:\Program files\Folder4")
For Each Str As String In New_paths
If Not Old_Path_Ary.Contains(LCase(Str)) Then
Old_Path_Ary.Add(Str)
End If
Next
Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("TRUSTEDPATHS", String.Join(";", Old_Path_Ary.ToArray()))
End Sub
Valued Mentor
Ajilal.Vijayan
Message 2 of 3 (316 Views)
Re: Adding trusted locations via DLL vb,net
04-15-2014 08:04 AM in reply to: makepeace1
            End If
        Next
    End Sub
Valued Contributor
Ron_M
Message 3 of 3 (258 Views)
04-18-2014 06:28 AM in reply to: Ajilal.Vijayan
Just adding in my two cents.  I've been working through the Options tabs to consolidate a 'stock' setting for our company.  This is what I have so far.  A few differences from what has been previously posted.
    <CommandMethod("setconfig")> _
    Public Sub setconfig()
        Dim acpref As AcadPreferences = Application.Preferences
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Try
            'Misc Variables
            Application.SetSystemVariable("filedia", 1)
            Application.SetSystemVariable("gridmode", 0)
            Application.SetSystemVariable("copymode", 0)
            acDoc.Window.WindowState = Window.State.Maximized
            acpref.System.BeepOnError = False
            Application.SetSystemVariable("trustedpaths", ";C:\Forum_ACAD\2014\;" & ";R:\2014\;")
            'Files
            acpref.Files.SupportPath = ";C:\Forum_ACAD\2014\" & ";R:\2014\;" & acpref.Files.SupportPath
            'acpref.Files.EnterpriseMenuFile = "R:\2014\Menus\Forum-2014.cuix"
            acpref.Files.PrinterConfigPath = "R:\2014\Plotters\"
            acpref.Files.PrinterDescPath = "R:\2014\Plotters\"
            acpref.Files.PrintSpoolerPath = "C:\Temp\"
            acpref.Files.PrinterStyleSheetPath = "R:\2014\Plotters\"
            acpref.Files.TemplateDwgPath = "R:\2014\Templates\"
            acpref.Files.QNewTemplateFile = "R:\2014\Templates\file-types.dwt"
            acpref.Files.TempFilePath = "C:\Temp\"
            'Display
            acpref.Display.DisplayScrollBars = False
            acpref.Display.XRefFadeIntensity = 50
            acpref.Display.GraphicsWinModelBackgrndColor = 0
            acpref.Display.CursorSize = 100
            acpref.Display.LayoutDisplayPaperShadow = False
            'acpref.Display.ModelCrosshairColor = "Color 42"
            'Open Save
            acpref.OpenSave.SaveAsType = Autodesk.AutoCAD.Interop.Common.AcSaveAsType.ac2013_dwg
            acpref.OpenSave.SavePreviewThumbnail = False
            acpref.OpenSave.AutoSaveInterval = False
            acpref.OpenSave.IncrementalSavePercent = 0
            acpref.OpenSave.CreateBackup = False
            acpref.OpenSave.FullCRCValidation = True
            acpref.OpenSave.LogFileOn = False
            acpref.OpenSave.MRUNumber.Equals("10")
            acpref.OpenSave.DemandLoadARXApp = Autodesk.AutoCAD.Interop.Common.AcARXDemandLoad.acDemandLoadOnObjectDetect
            acpref.OpenSave.AutoAudit = True
            acpref.OpenSave.ShowProxyDialogBox = False
            acpref.OpenSave.TempFileExtension = "ac$"
            acpref.OpenSave.XrefDemandLoad = Autodesk.AutoCAD.Interop.Common.AcXRefDemandLoad.acDemandLoadEnabled
            acpref.OpenSave.ProxyImage = False
            ''Plot and Publish
            acpref.Output.AutomaticPlotLog = False
            acpref.Output.ContinuousPlotLog = False
            acpref.Output.DefaultOutputDevice = "Adobe PDF"
            Application.SetSystemVariable("BackGroundPlot", 0)
            Application.SetSystemVariable("AutomaticPub", 0)
            ''Drafting
            acpref.Drafting.AutoTrackTooltip = False
            acpref.Drafting.AutoSnapTooltip = False
            acpref.Drafting.AlignmentPointAcquisition = 0
        Catch ex As Exception
        End Try
    End Sub
