I have got a lsp that add's the trusted location's to autocad if the version of autocad that is running is 2014 or above
(if (>= (getvar "ACADVER") "19.1") (setvar "trustedpaths" (strcat (getvar "trustedpaths") "c:\\folder1;" "c:\\folder2;" "c:\\folder3;" "c:\\folder4;" )))
How would i be able to add that to my DLL to check if the trusted locations were already there if not to add them ?
Solved by Ajilal.Vijayan. Go to Solution.
Same method that we used for Support path.
Public Sub gettrust() Dim str_TR As String = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("TRUSTEDPATHS") Dim C_Paths As String = LCase(str_TR) Dim Old_Path_Ary As List(Of String) = New List(Of String) Old_Path_Ary = C_Paths.Split(";").ToList Dim New_paths As List(Of String) = New List(Of String) New_paths.Add("C:\Program files\Folder1") New_paths.Add("C:\Program files\Folder2") New_paths.Add("C:\Program files\Folder3") New_paths.Add("C:\Program files\Folder4") For Each Str As String In New_paths If Not Old_Path_Ary.Contains(LCase(Str)) Then Old_Path_Ary.Add(Str) End If Next Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("TRUSTEDPATHS", String.Join(";", Old_Path_Ary.ToArray())) End Sub
Just adding in my two cents. I've been working through the Options tabs to consolidate a 'stock' setting for our company. This is what I have so far. A few differences from what has been previously posted.
<CommandMethod("setconfig")> _ Public Sub setconfig() Dim acpref As AcadPreferences = Application.Preferences Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument Try 'Misc Variables Application.SetSystemVariable("filedia", 1) Application.SetSystemVariable("gridmode", 0) Application.SetSystemVariable("copymode", 0) acDoc.Window.WindowState = Window.State.Maximized acpref.System.BeepOnError = False Application.SetSystemVariable("trustedpaths", ";C:\Forum_ACAD\2014\;" & ";R:\2014\;") 'Files acpref.Files.SupportPath = ";C:\Forum_ACAD\2014\" & ";R:\2014\;" & acpref.Files.SupportPath 'acpref.Files.EnterpriseMenuFile = "R:\2014\Menus\Forum-2014.cuix" acpref.Files.PrinterConfigPath = "R:\2014\Plotters\" acpref.Files.PrinterDescPath = "R:\2014\Plotters\" acpref.Files.PrintSpoolerPath = "C:\Temp\" acpref.Files.PrinterStyleSheetPath = "R:\2014\Plotters\" acpref.Files.TemplateDwgPath = "R:\2014\Templates\" acpref.Files.QNewTemplateFile = "R:\2014\Templates\file-types.dwt" acpref.Files.TempFilePath = "C:\Temp\" 'Display acpref.Display.DisplayScrollBars = False acpref.Display.XRefFadeIntensity = 50 acpref.Display.GraphicsWinModelBackgrndColor = 0 acpref.Display.CursorSize = 100 acpref.Display.LayoutDisplayPaperShadow = False 'acpref.Display.ModelCrosshairColor = "Color 42" 'Open Save acpref.OpenSave.SaveAsType = Autodesk.AutoCAD.Interop.Common.AcSaveAsType.ac2013_dwg acpref.OpenSave.SavePreviewThumbnail = False acpref.OpenSave.AutoSaveInterval = False acpref.OpenSave.IncrementalSavePercent = 0 acpref.OpenSave.CreateBackup = False acpref.OpenSave.FullCRCValidation = True acpref.OpenSave.LogFileOn = False acpref.OpenSave.MRUNumber.Equals("10") acpref.OpenSave.DemandLoadARXApp = Autodesk.AutoCAD.Interop.Common.AcARXDemandLoad.acDemandLoadOnObjectDetect acpref.OpenSave.AutoAudit = True acpref.OpenSave.ShowProxyDialogBox = False acpref.OpenSave.TempFileExtension = "ac$" acpref.OpenSave.XrefDemandLoad = Autodesk.AutoCAD.Interop.Common.AcXRefDemandLoad.acDemandLoadEnabled acpref.OpenSave.ProxyImage = False ''Plot and Publish acpref.Output.AutomaticPlotLog = False acpref.Output.ContinuousPlotLog = False acpref.Output.DefaultOutputDevice = "Adobe PDF" Application.SetSystemVariable("BackGroundPlot", 0) Application.SetSystemVariable("AutomaticPub", 0) ''Drafting acpref.Drafting.AutoTrackTooltip = False acpref.Drafting.AutoSnapTooltip = False acpref.Drafting.AlignmentPointAcquisition = 0 Catch ex As Exception End Try End Sub
