.NET
.NET
Active Member
0 Kudos
Post 1 of 4
Adding Properties Palette to a Custom Made Palette Set
350 Views, 3 Replies
02-02-2012 04:41 AM
Hi all,
Does anybody know if it is possible to add the Properties Palette to a custom made palette set in .NET? And how to do this?
Thanks!
ADN Support Specialist
46 Kudos
Post 2 of 4
Re: Adding Properties Palette to a Custom Made Palette Set
02-02-2012 05:18 AM in reply to: jparts
So do you want to include the property pallete inside your custom pallete? Never saw it, altough you can implement a similar feature on your palette using the Selection Implied event.
If is the other way, take a look at http://through-the-interface.typepad.com/through_the_interface/2008/11/adding-custom-p.html
Augusto Goncalves
Autodesk Developer Network
Active Member
0 Kudos
Post 3 of 4
02-02-2012 05:36 AM in reply to: augusto.goncalves
Yes I want to add the properties palette to a custom palette set. I've managed to do the same for the calculator (found an example here: http://forums.autodesk.com/autodesk/attachments/autodesk/152/26712/1/CP205-2_Mike_Tuersley.pdf )
I'm using AutoCAD Mechanical 2012 x64 by the way.
The code for adding the calculator looks something like this: (I had to reference AcCalcUi.dll to the project)
'IMPORTS FOR ADDING CALCULATOR TO PALETTESET
Imports Autodesk.AutoCAD.CalculatorUI
Imports CalcDialogCreator
Public Class myCommands
  Friend Shared m_ps As PaletteSet = Nothing
 <CommandMethod("MarelPallette")> Public Sub MarelPallette()
    If m_ps = Nothing Then
      m_ps = New PaletteSet("Marel")
      m_ps.Add("BeamPlan", New uscBeamPlan)
      m_ps.Add("Building Provisions", New uscBuildingProvisions)
      'CODE FOR ADDING CALCULATOR TO PALETTESET
      Dim ucCalc As New System.Windows.Forms.UserControl
      ucCalc = New CalculatorControl.AcCalcCalcCtrl(ucCalc)
      m_ps.Add("Calculator", ucCalc)
    End If
    m_ps.Visible = True
  End Sub
 Now I was wondering if there is a similar option for adding the properties palette to my palette set.
Best Regards,
Joris
Active Member
0 Kudos
Post 4 of 4
02-07-2012 12:26 AM in reply to: jparts
Does anybody have an idea how to do this???
