.NET
Adding new TextStyleRecord/MLeaderStyle
1 REPLY 1
Rob.O
971 Views, 1 Reply
I have a some working code that checks for the existence of a text style, and creates it if it does not exist.  It then checks for the existence of an mleader style and creates it if it does not exist.  It then adds a new mleader object.  This new mleader style uses the new text style.
The code works great, but there is one thing I do not understand.  If the text style that the mleader style uses already exists, then new mleaders are created with no problem regardless of what the current text style is set to.  But, if the text style does not exist, I had to make the new text style current in order for the new mleaders I added to the drawing show with the proper text style (even though  the new mleader style is set correctly to the new text style).
Am I doing somthing wrong?
<SNIP>
Dim mlstyleid As ObjectId
                Dim m As MLeader = New MLeader()
                m.LeaderLineType = LeaderType.StraightLeader
                'Set mleader points from user picks
                m.AddLeaderLine(arrowPoint)
                m.AddLastVertex(0, symbolPoint)
                Dim mlname As String = strMlStyle
                Dim dict As DBDictionary = CType(acTrans.GetObject(acDb.MLeaderStyleDictionaryId, OpenMode.ForRead), DBDictionary)
                If Not dict.Contains(strMlStyle) Then
                    Dim newMleadStyle As New MLeaderStyle()
                    newMleadStyle.PostMLeaderStyleToDb(acDb, mlname)
                    newMleadStyle.Annotative = AnnotativeStates.[True]
                    newMleadStyle.DrawMLeaderOrderType = DrawMLeaderOrderType.DrawLeaderFirst
                    newMleadStyle.LeaderLineColor = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.ByLayer, 256)
                    newMleadStyle.TextAlignAlwaysLeft = True
                    newMleadStyle.LeaderLineType = LeaderType.StraightLeader
                    newMleadStyle.ContentType = ContentType.MTextContent
                    newMleadStyle.ArrowSize = 0.09375
                    newMleadStyle.BreakSize = 0.0625
                    newMleadStyle.DoglegLength = 0.125
                    newMleadStyle.EnableLanding = True
                    newMleadStyle.EnableDogleg = True
                    newMleadStyle.EnableFrameText = False
                    newMleadStyle.LandingGap = 0.0625
                    newMleadStyle.MaxLeaderSegmentsPoints = 2
                    ' Get the objectID of the ECDT text style
                    Dim textStyleTbl As TextStyleTable = acDb.TextStyleTableId.GetObject(OpenMode.ForRead)
                    Dim TxtRcd As TextStyleTableRecord
                    Dim newTxtRcd As New TextStyleTableRecord
                    If textStyleTbl.Has("ECDT") Then
                        TxtRcd = textStyleTbl("ECDT").GetObject(OpenMode.ForRead)
                    Else
                        ' If text style does not exist, create it
                        newTxtRcd.Name = "ECDT"
                        textStyleTbl.UpgradeOpen()
                        textStyleTbl.Add(newTxtRcd)
                        Dim acNewFont As Autodesk.AutoCAD.GraphicsInterface.FontDescriptor
                        acNewFont = New Autodesk.AutoCAD.GraphicsInterface.FontDescriptor("Century Gothic", False, False, 0, 0)
                        newTxtRcd.Font = acNewFont
                        acTrans.AddNewlyCreatedDBObject(newTxtRcd, True)
                    End If
                    acDb.Textstyle = TxtRcd.ObjectId
                    newMleadStyle.TextStyleId = TxtRcd.ObjectId
<SNIP>
TIA
1 REPLY 1
Hallex
in reply to: Rob.O
I would use separate functions and subs instead of creating long spaghetti code
And also you could be use Try..Catch to find the bad code block easily
Here is a quick example, not so elegant though
Tested on A2009 (eng) only
        Public Shared Sub MainCallingSub()
            Try
                Dim txtid As ObjectId = GetOrCreateTextStyle("MyTextStyle", "Century Gothic", "", 2.0)
                Dim mldid As ObjectId = GetOrCreateMleaderStyle("MyMleaderStyle", txtid)
                Dim cmldStyle As Object = "MyMleaderStyle"
                Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("CMLEADERSTYLE", cmldStyle)
                DrawMleader(txtid)
            Catch ex As System.Exception
                Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(ex.Message & vbLf & ex.ToString)
            End Try
        End Sub
        Public Shared Sub DrawMleader(ByVal txtId As ObjectId)
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim ed As Editor = doc.Editor
            Dim ucs As CoordinateSystem3d = ed.CurrentUserCoordinateSystem.CoordinateSystem3d
            Dim db As Database = HostApplicationServices.WorkingDatabase
            Dim plan As Plane = New Plane(Point3d.Origin, ucs.Zaxis)
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Try
                    Dim pts As Point3dCollection = New Point3dCollection()
                    pts.Add(New Point3d(0, 0, 0))
                    pts.Add(New Point3d(10, 10, 0))
                    Dim ml As MLeader = New MLeader()
                    ml.SetDatabaseDefaults()
                    'change some mleader properties if it is needed:
                    ml.LeaderLineType = LeaderType.StraightLeader
                    ml.AddLeaderLine(pts(0))
                    ml.AddLastVertex(0, pts(1))
                    ml.ContentType = ContentType.MTextContent
                    Dim mt As New MText()
                    mt.SetDatabaseDefaults()
                    mt.Contents = "1. Alpha\P2. Bravo\P3. Charlie"
                    'change some text properties if it is needed:
                    mt.TextHeight = 1.0
                    mt.TextStyle = txtId
                    ml.ArrowSize = 0.25
                    ml.MText = mt
                    ml.EnableFrameText = False
                    ml.EnableLanding = True
                    ml.LandingGap = 0.1
                    ml.TextAttachmentType = TextAttachmentType.AttachmentBottomLine
                    ml.TextAngleType = TextAngleType.HorizontalAngle
                    ml.EnableDogleg = True
                    Dim i As Integer = 0
                    ml.SetDoglegLength(i, 0.1)
                    'dog leg direction:
                    If (pts(0).X < pts(1).X) Then
                        ml.SetDogleg(i, New Vector3d(plan, New Vector2d(1, 0)))
                        ml.TextAlignmentType = TextAlignmentType.LeftAlignment
                    Else
                        ml.SetDogleg(i, New Vector3d(plan, New Vector2d(-1, 0)))
                        ml.TextAlignmentType = TextAlignmentType.RightAlignment
                    End If
                    Dim btr As BlockTableRecord = CType(tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead), BlockTableRecord)
                    btr.UpgradeOpen()
                    btr.AppendEntity(ml)
                    btr.DowngradeOpen()
                    tr.AddNewlyCreatedDBObject(ml, True)
                    tr.Commit()
                Catch ex As Autodesk.AutoCAD.Runtime.Exception
                    ed.WriteMessage(vbCr & ex.Message & vbCr & ex.ToString)
                Finally
                    If Not tr.IsDisposed Then tr.Dispose()
                End Try
            End Using
        End Sub
        Public Shared Function GetOrCreateMleaderStyle(ByVal strMlStyle As String, ByVal txid As ObjectId) As ObjectId
            Dim acDoc As Document = acApp.DocumentManager.MdiActiveDocument
            Dim ed As Editor = acDoc.Editor
            Dim acDb As Database = HostApplicationServices.WorkingDatabase
            Dim id As ObjectId = ObjectId.Null
            Using doclock As DocumentLock = acDoc.LockDocument
                Using acTrans As Transaction = acDb.TransactionManager.StartTransaction()
                    Try
                        If dict.Contains(strMlStyle) Then
                            id = dict.GetAt(strMlStyle)
                        Else
                            newMleadStyle.TextAlignAlwaysLeft = False
                            newMleadStyle.Annotative = AnnotativeStates.True
                            newMleadStyle.TextAttachmentType = TextAttachmentType.AttachmentBottomOfTopLine
                            newMleadStyle.TextStyleId = txid
                            newMleadStyle.PostMLeaderStyleToDb(acDb, strMlStyle)
                            newMleadStyle.DowngradeOpen()
                            id = newMleadStyle.ObjectId
                            acTrans.Commit()
                            ed.Regen()
                            ''check again
                                ed.WriteMessage(vbCr & "MLeaderSyle was created sucessfully")
                            End If
                        End If
                        ed.WriteMessage(ex.Message)
                        id = ObjectId.Null
                    Finally
                    End Try
                End Using
            End Using
            Return id
        End Function
        Public Shared Function GetNonErasedTableRecordId(ByVal TableId As ObjectId, ByVal Name As String) As ObjectId
            ' as posted by Tony Tanzillo 01 Sept 2006
            Using tr As Transaction = TableId.Database.TransactionManager.StartTransaction()
                Dim table As SymbolTable = DirectCast(tr.GetObject(TableId, OpenMode.ForRead), SymbolTable)
                If table.Has(Name) Then
                    id = table(Name)
                    If Not id.IsErased Then
                        Return id
                    End If
                    For Each recId As ObjectId In table
                        If Not recId.IsErased Then
                            Dim rec As SymbolTableRecord = DirectCast(tr.GetObject(recId, OpenMode.ForRead), SymbolTableRecord)
                            If String.Compare(rec.Name, Name, True) = 0 Then
                                Return recId
                            End If
                        End If
                    Next
                End If
            End Using
            Return id
        End Function
        Public Shared Function GetTextStyle(ByVal stylename As String) As ObjectId
            Return GetNonErasedTableRecordId(db.TextStyleTableId, stylename)
        End Function
        Public Shared Function CreateTextStyle(ByVal stylename As String, ByVal filename As String, ByVal bgfilename As String, ByVal textheight As Double) As ObjectId
            Dim tr As Transaction = doc.TransactionManager.StartTransaction()
            Using tr
                Try
                    Dim tst As TextStyleTable = DirectCast(tr.GetObject(db.TextStyleTableId, OpenMode.ForRead, False), TextStyleTable)
                    Dim ts As New TextStyleTableRecord()
                    ts.Name = stylename
                    ts.FileName = filename
                    If bgfilename <> String.Empty Then
                        ts.BigFontFileName = bgfilename
                    End If
                    ts.TextSize = textheight
                    ts.XScale = 1.0
                    tst.UpgradeOpen()
                    tst.Add(ts)
                    tr.AddNewlyCreatedDBObject(ts, True)
                    id = ts.ObjectId
                    tr.Commit()
                    ed.WriteMessage(vbCr & ex.Message)
                End Try
                Return id
            End Using
        End Function
        Public Shared Function GetOrCreateTextStyle(ByVal stylename As String, ByVal fontfilename As String, ByVal bgfilename As String, ByVal textheight As Double) As ObjectId
            id = GetTextStyle(stylename)
            If id = ObjectId.Null Then
                id = CreateTextStyle(stylename, fontfilename, bgfilename, textheight)
            End If
            Return id
        End Function
~'J'~
”Boost
