.NET
Adding custom code in reference editing and RefEdit command
4 REPLIES 4
RamanSBV
482 Views, 4 Replies
Could you please any body suggest, how i can add .net code on reference editing and refedit command.
Raman
4 REPLIES 4
Alfred.NESWADBA
in reply to: RamanSBV
follow these steps:
  • get the BlockTable within your current drawing
  • go through the items in the BlockTable (type ObjectID for BlockTableRecord) and check if it's your XRef
  • if you found it you have access to it's database then to modify it.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Do you want to replace the command REFEDIT with your code?
Then try this code: http://forums.autodesk.com/t5/NET/Override-default-commands/m-p/3402455#M28099
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Thanks for this link.....
Could you please guide me how i can get the "Select reference:" value in REFEDIT command.
Raman
RamanSBV
Here,
How i can get the "Select reference:"  Xref file path value in REFEDIT command.
Please guide me.
Raman
”Boost
