Could you please any body suggest, how i can add .net code on reference editing and refedit command.
Raman
follow these steps:
- alfred -
Do you want to replace the command REFEDIT with your code?
Then try this code: http://forums.autodesk.com/t5/NET/Override-default-commands/m-p/3402455#M28099
Facebook | Twitter | LinkedIn
Thanks for this link.....
Could you please guide me how i can get the "Select reference:" value in REFEDIT command.
Raman
Here,
How i can get the "Select reference:" Xref file path value in REFEDIT command.
Please guide me.
Raman
