Anyone knows how to improve the memory allocation of autocad.net application. I often get autocad crashes in the application and most of the cause is how autocad handles the memory. i am not sure if it is application related or if there is a way to configure the application to have stable memory allocation.
Everytime I do add autocad objects and delete autocad objects programmatically the memory always sky rocket and I am very very very frustrated.I would really appreciate any tips or help to improve the performance.
Thanks and regards
Please note that I am using intel corei5 2.5Ghz and 4G of memory. I dont think adding more memory is the solutions. I really do think it has something to do with configuring this autocad application in .net. I just dont know how to do it.
once you have added an object or deleted it, did you use Transction.Commit() and then Dispose the transcation(by using Transction.Dispose())? could you post some snippet of your code that crush autocad?
here a sample coding I normally do
Using lock As DocumentLock = doc.LockDocument
Dim trans As Transaction = db.TransactionManager.StartTransaction()
Try
Using trans
Dim bt As BlockTable =
trans.GetObject(db.BlockTableId,
Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead)
Dim modelSpace As BlockTableRecord =
trans.GetObject(bt(BlockTableRecord.ModelSpace),
Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)
modelSpace.AppendEntity(br)
trans.AddNewlyCreatedDBObject(br, True)
trans.Commit()
End Using
Catch ex As Exception
trans.Dispose()
Finally
trans.Dispose()
End Try
End Using
It is very likely that you was led to think it was AutoCAD memory management issue when your code crashes AutoCAD, causing fatal error message, which mentions something about accessing memory error.
4G memory in computer may not be good enough for AutoCAD runs smoothly, but it should runs OK, and disk space would be used if more memory i sneeded (to make computer even slower). But your case of crash is very possibly caused by your code that does not handle exception good enough.
The code you just showed seems OK, as long as in the call:
AppendEntity(br), where br is an Entity (BlockReference?).
Have you stepping through the code in debugging mode to identify which line of code causes the crash?
Norman Yuan
OK, amigo, i rarely use VB.NET to code, just have some experience in VB 6.0.
as your code shows, can you explain the variable 'br' means? in some languages like c#, we should declare a variable before we use it, whereas in VB, you can use it immediately, so here your 'br' has no type(variant type, if you insist it has one), unlike other strong type languages, this may cause type cast at runtime, so here your code may need more time and resources to try to execute, but, but your 'br' is null here, so your code may crash.
how about:
Dim br as Line...
and write some code.
finally, i usually handle the exception like this(C# style):
try
catch
trans.abort();
throw;
finally
trans.dispose();
hope this may be helpful to you.
Hi cdinten,
Thanks for the sample snippet. I am currently recoding because from what I read from blogs and autodesk comment normally when you use using keyword on transaction it normally automatically dispose the transaction. I am trying to put all objects like polyline, dbobject, entity etc. inside using keyword and hope it will help improve the performance and put an end to crashes. I'll keep you posted after I'm done with recoding the program.
Got the idea from this link: http://through-the-interface.typepad.com/through_the_interface/2010/03/the-stephen-and-fenton-show-a....
