.NET
.NET
Valued Contributor
2 Kudos
Post 1 of 6
Adding a View (viewTableRecord) to Paper Space Layout
440 Views, 5 Replies
01-16-2013 01:13 PM
I have used the following code in a small app to create named views: LINK_TO_Autodesk_Help_Topic
HOWEVER...A user of mine tried running the command while in a paper space layout.  It appears the view still gets created but only within Model Space.
The help DOES SAY that "a default model space view is created", but how would I specify that I want the view to be created within the "current" layout, either Model or Paper space?
I tried setting the .OwnerID property of the ViewTableRecord to "doc.CurrentSpaceID" but that did not work - no error either.
This is the same in my code:
pViewTR.IsPaperspaceView = true;
171 Kudos
Post 2 of 6
Re: Adding a View (viewTableRecord) to Paper Space Layout
01-17-2013 12:19 AM in reply to: spanqy
Spoiler
See article here
http://adndevblog.typepad.com/autocad/2012/08/create-paper-space-viewports.html
Here is a code very quickly translated on C#:
        [CommandMethod("VW")]
        public void tryCreateViewPort()
            // Only works in paperspace
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            try
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    ObjectId mCurViewportId = ed.ActiveViewportId;
                    if (mCurViewportId == ObjectId.Null)
                        ed.WriteMessage("\nCommand only works in paperspace.");
                        return;
                    Viewport pCurViewport = tr.GetObject(mCurViewportId, OpenMode.ForRead) as Viewport;
                    if (pCurViewport == null)
                        ed.WriteMessage("\nCannot get active viewport.");
                        return;
                    if (pCurViewport.Number != 1)
                        return;
                    // Ask for the position
                    Point3d pt1; Point3d pt2;
                    pt1 = ed.GetPoint("\nSelect first corner: ").Value;
                    pt2 = ed.GetCorner("\nSelect second corner: ", pt1).Value;
                    // Ask for the view to use
                    string mViewName;
                    mViewName = ed.GetString("\nEnter name of view to use: ").StringResult;
                    // Create new viewport
                    Viewport pViewport = new Viewport();
                    pViewport.Width = Math.Abs(pt2.X - pt1.X);
                    pViewport.Height = Math.Abs(pt2.Y - pt1.Y);
                    pViewport.CenterPoint = new Point3d(
                      pt1.X + (pt2.X - pt1.X) / 2,
                      pt1.Y + (pt2.Y - pt1.Y) / 2,
                      pt1.Z);
                    // Append new viewport to paper space
                    BlockTable pTable;
                    BlockTableRecord pPsBTR;
                    pTable = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                    pPsBTR = (BlockTableRecord)tr.GetObject(pTable[BlockTableRecord.PaperSpace], OpenMode.ForWrite);
                    ObjectId mViewPortId = pPsBTR.AppendEntity(pViewport);
                    tr.AddNewlyCreatedDBObject(pViewport, true);
                    pViewport.On = true;
                    pViewport.FastZoomOn = true;
                    pViewport.SetUcs(pViewport.CenterPoint, Vector3d.XAxis, Vector3d.YAxis);
                    // Set the view
                    ViewTable pViewTable = (ViewTable)tr.GetObject(db.ViewTableId, OpenMode.ForRead);
                    // initialize the layout
                   // Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("TILEMODE", 0);
                  //  Layout layout = tr.GetObject(pPsBTR.LayoutId, OpenMode.ForWrite) as Layout;
                    //  LayoutManager.Current.CurrentLayout = "Layout2";
                    // layout.Initialize();
                    ViewTableRecord pViewTR;
                    if (pViewTable.Has(mViewName))
                        pViewTR = (ViewTableRecord)tr.GetObject(pViewTable[mViewName], OpenMode.ForWrite);
                    else
                        pViewTR = new ViewTableRecord();
                        pViewTR.Name = mViewName;
                        pViewTable.UpgradeOpen();
                        ObjectId vtId = pViewTable.Add(pViewTR);
                        tr.AddNewlyCreatedDBObject(pViewTR, true);
                    ed.SetCurrentView(pViewTR);
                    tr.Commit();
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                ed.WriteMessage(ex.Message + "\n" + ex.StackTrace);
            finally
Valued Contributor
2 Kudos
Post 3 of 6
01-17-2013 07:47 AM in reply to: Hallex
I really appreciate you taking the time to reply but...
Your post and the link refer to a paper space "Viewport" like you do manually with the "MVIEW" command. What I needed to do was create a "View" in paper space like you do manually with the "VIEW" command.
Regards
Moderator
277 Kudos
Post 4 of 6
01-17-2013 09:08 AM in reply to: spanqy
ViewTableRecord.IsPaperspaceView = true can help you
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
171 Kudos
Post 5 of 6
01-17-2013 12:39 PM in reply to: Alexander.Rivilis
Valued Contributor
2 Kudos
Post 6 of 6
01-17-2013 12:54 PM in reply to: Hallex
That was easy!
Thank you both Hallex and Alexander!
