.NET
Adding a document to documentmanager collection
7 REPLIES 7
Message 1 of 8
GeeHaa
1004 Views, 7 Replies
The code below crashes with an "attempt to write to protected memory"  in debug mode (it crashes when it hits acDocMgr.add)but in the Release version it works fine. Should I be worried? I am using Command Flags.Session
Dim acDocMgr As DocumentCollection = Application.DocumentManager
Dim pStyle As Integer = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("PSTYLEMODE")
Dim acDoc As Document = Nothing
If pStyle = 1 Then
   acDoc = acDocMgr.Add("acad.dwt")
Else
acDoc = acDocMgr.Add("acad -Named Plot Styles.dwt")
 Thanks in Advance
7 REPLIES 7
Message 2 of 8
sszabo
in reply to: GeeHaa
try this: acDoc = DocumentCollectionExtension.Add(acDocMgr, "acad.dwt")instead.
Message 3 of 8
GeeHaa
in reply to: GeeHaa
Thanks for the reply,
I tried using the documentcollectionextension but it still has the same error.
this appears in the imediate window
A first chance exception of type 'Autodesk.AutoCAD.Runtime.Exception' occurred in AcdbMgd.dll
Message 4 of 8
sszabo
in reply to: GeeHaa
It sounds like a multi threading issue but without the whole project attached I can't tell what's going on, sorry.
Message 5 of 8
Hallex
in reply to: GeeHaa
Try add to Reference: accoremgd.dll
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 6 of 8
GeeHaa
in reply to: Hallex
Nevermind I figured it out. I have a startup sequence in my ACAD.Doc file that makes a call to VBA  to pop up a messagebox if the filename doesn't match the drawing number. I disabled it and it runs fine now in debug mode. I'm still wondering why the release version ran fine though.
Thanks Again
Message 7 of 8
sszabo
in reply to: GeeHaa
In debug mode you are running under msvsmon and your VBA code is running under acad.  You would probably have to use InvokeRequired around your Document object for this to work, again just guessing here.
Message 8 of 8
GeeHaa
in reply to: sszabo
I'm Sorry I meant AcadDoc.lsp file.
”Boost
