.NET
addin folder location
4 REPLIES 4
Dale.Bartlett
1096 Views, 4 Replies
Hi, Is there any way to return the path to the dll that has been used in Netload the addin application? Dale
______________
Yes, I'm Satoshi.
4 REPLIES 4
http://adndevblog.typepad.com/autocad/2012/05/listing-loaded-net-assemblyprogram-in-autocad.html
Facebook | Twitter | LinkedIn
Expert Elite Member
Or: System.Windows.Forms.Application.StartupPath
[System.Windows.Forms.Application.StartupPath] returns the path to acad.exe. That was my first attempt. I have used the previous blog example successfully. Thanks for response. Dale.
______________
Yes, I'm Satoshi.
What about ....ExecutablePath? does it also return the ACAD.exe?
Sorry, I use VB, and My.Application.Info.DirectoryPath returns the Path to my .dll, not the Acad.exe.  The search I did said that Application.StartupPath was the C# equivalent.  Just thought it would be easier than all the code in the DevBlog.
”Boost
