.NET
MarkPendergraft
Message 1 of 3 (292 Views)
AddAllowedClass in GetEntity
292 Views, 2 Replies
10-12-2006 12:26 PM
I'm writing a program to list specific survey related data of Lines, Arcs, and Polylines.
i use the GetEntity function of the Editor.
I want to filter the types of objects that the user is allowed to pick.
I have seen code in C# using the AddAllowedClass of the PromptEntityOptions object. However i cannot seem to get it to work.
Here is my code thus far.....
Public Sub ListSurveyData()
Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
Dim db As Database = HostApplicationServices.WorkingDatabase
Dim prEntOpt As PromptEntityOptions = New PromptEntityOptions("Select an Arc or Line: ")
''''Cant figure this part out. !!!!
prEntOpt.AddAllowedClass(Type.GetType(Line), True)
prEntOpt.AddAllowedClass(Type.GetType(Polyline), True)
prEntOpt.AddAllowedClass(Type.GetType(Arc), True)
prEntOpt.AllowNone = False
Dim prEntRes As PromptEntityResult = ed.GetEntity(prEntOpt)
If prEntRes.Status PromptStatus.OK Then Exit Sub
End Sub
Distinguished Contributor
jbooth
Message 2 of 3 (292 Views)
Re: AddAllowedClass in GetEntity
10-12-2006 03:01 PM in reply to: MarkPendergraft
Type.GetType() requires a string. Use the GetType operator instead of calling the GetType method of the System.Type class.
ie: use GetType(Line) instead of Type.GetType(Line)
If it still doesn't work, feel free to post again. :smileywink:
MarkPendergraft
Message 3 of 3 (292 Views)
10-12-2006 03:15 PM in reply to: MarkPendergraft
i found a website half in japanese, with the code in english, and figured it out...... i needed to use GetType instead of type.gettype()
Announcements
Need installation help?
