.NET
Add trusted folder
4 REPLIES 4
andre_adc-dao
1128 Views, 4 Replies
Add trusted folder
In 2014, you have trusted or approved folder search path. I'm able to add search path programmatically but I cannot found how to add trusted folder.
Anybody have a clue?
André
4 REPLIES 4
BlackBox_
in reply to: andre_adc-dao
If I am understanding you correctly, you're after this, found in TRUSTEDPATHS documentation:
AutoCAD Online Help, TRUSTEDPATHS (System Variable)
  • When TRUSTEDPATHS includes a folder that ends with \... (backslash and three dots), all of its subfolders are also trusted.
"How we think determines what we do, and what we do determines what we get."
andre_adc-dao
in reply to: BlackBox_
Thank you,
I was trying to add trusted folder using Application.Preferences and  I was looking for Files.SupportPath equivalent to trustedpaths. I didn't know there is a system variable. I will use this variable to add trusted path.
André
BlackBox_
You're welcome; I'm happy to help.
Don't forget to please mark the post as solution.
Cheers
andre_adc-dao
It works perfectly using the system variable TRUSTEDPATHS.
Thank you very much,
André
”Boost
