.NET
Active Contributor
matt.worland
Message 1 of 4 (187 Views)
Add text in nested transaction
187 Views, 3 Replies
10-09-2013 12:09 PM
I am fairly new to .net and Im trying to figure out what I can do differently in my code to have it show the newly placed text immediately after choosing an insertion point. Im guessing it has to do with a nested transaction and my loop, but Im not sure how to fix.
Also, anything else to optimize in the code, please feel free to pick apart.
The code below is to label the layer of a selected entity. If in paperspace, label in paperspace and if in modelspace label in modelspace. Ive been testing this on the "blocks_and_tables_-_imperial.dwg"
matt
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices.Application
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Public Class Class2
    Public Function myAnnotate(myDbIn As Database, mySpace As String, myTextContents As String, mySTPT As Point3d) As ObjectId
        Try
            Using myTrans As Transaction = myDbIn.TransactionManager.StartTransaction
                'Dim myStartPt As Point3d = DocumentManager.MdiActiveDocument.Editor.GetPoint("Pick insertion point: ").Value
                Dim myBT As BlockTable = myDbIn.BlockTableId.GetObject(OpenMode.ForRead)
                Dim myInSpace As BlockTableRecord
                Dim myMText As New MText()
                myMText.Location = mySTPT
                If mySpace = "MODEL" Then
                    myInSpace = myBT(BlockTableRecord.ModelSpace).GetObject(OpenMode.ForWrite)
                Else
                    myInSpace = myBT(BlockTableRecord.PaperSpace).GetObject(OpenMode.ForWrite)
                End If
                myMText.Contents = myTextContents
                myMText.TextHeight = 0.0625
                myMText.Attachment = AttachmentPoint.BottomLeft
                myMText.BackgroundFill = True
                myInSpace.AppendEntity(myMText)
                myTrans.AddNewlyCreatedDBObject(myMText, True)
                myTrans.Commit()
            End Using
        Catch ex As System.Exception
        End Try
    End Function
    <CommandMethod("LayAnno")> _
    Public Sub LayAnno()
        Dim myDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim myDb As Database = myDoc.Database
        Dim myEd As Editor = myDoc.Editor
        Dim myTr As Transaction = myDb.TransactionManager.StartTransaction
        Using myTr
            Dim mybt As BlockTable = myTr.GetObject(myDb.BlockTableId, OpenMode.ForRead)
            Dim mybtr As BlockTableRecord = myTr.GetObject(myDb.CurrentSpaceId, OpenMode.ForRead)
            Dim myCSFlag As String
            If myDb.TileMode Then
                myCSFlag = "MODEL"
            ElseIf myDb.CurrentSpaceId = SymbolUtilityServices.GetBlockModelSpaceId(myDb) Then
                myCSFlag = "MSPACE"
            Else
                myCSFlag = "PAPER"
                Dim vp As Viewport = TryCast(myTr.GetObject(myEd.CurrentViewportObjectId, OpenMode.ForRead), Viewport)
                myEd.SwitchToModelSpace()
            End If
            Dim myContFlag As Boolean = True
            Do While myContFlag = True
                Dim mycwPEO As New PromptEntityOptions("Select an entity to annotate:")
                Dim mycwPER As PromptEntityResult = myEd.GetEntity(mycwPEO)
                Select Case mycwPER.Status
                    Case EditorInput.PromptStatus.OK
                        Dim myEnt2 As Entity = mycwPER.ObjectId.GetObject(OpenMode.ForRead)
                        Dim myppo As PromptPointOptions = New PromptPointOptions(vbLf & "Select a Point: ")
                        Dim myppr As PromptPointResult
                        If myCSFlag = "MODEL" Then
                            myppr = myEd.GetPoint(myppo)
                        Else
                            myEd.SwitchToPaperSpace()
                        End If
                        Dim myVal As String = myEnt2.Layer.ToString
                        If myppr.Status <> PromptStatus.OK Then Exit Sub
                        Dim myStartPt As Point3d = myppr.Value
                        myAnnotate(myDb, myCSFlag, myVal, myStartPt)
                        myContFlag = True
                    Case EditorInput.PromptStatus.Cancel
                        myEd.WriteMessage("You cancelled.")
                        myContFlag = False
                    Case EditorInput.PromptStatus.Error
                        myContFlag = False
                        MsgBox("Error warning.")
                End Select
            Loop
            Else
            End If
            myTr.Commit()
        End Using
    End Sub
End Class
matt worland
Hallex
Message 2 of 4 (176 Views)
Re: Add text in nested transaction
10-09-2013 01:18 PM in reply to: matt.worland
On the quick glance you have to force
TransactionManager methods,
see marked (as <-- addedd) lines inline:
            myDoc.TransactionManager.EnableGraphicsFlush(True) '<--  added
            Using myTr
                    myCSFlag = "MODEL"
                    myCSFlag = "MSPACE"
                Else
                    myCSFlag = "PAPER"
                End If
                            Else
                            End If
                            myTr.TransactionManager.QueueForGraphicsFlush() '<--  added
                            myContFlag = True
                            myContFlag = False
                            myContFlag = False
                    End Select
                Loop
                Else
                End If
                myDoc.TransactionManager.FlushGraphics() '<--  added
                myTr.Commit()
            End Using
        End Sub
Active Contributor
matt.worland
Message 3 of 4 (164 Views)
10-09-2013 02:01 PM in reply to: Hallex
Thank you, that works nicely.
matt worland
Hallex
Message 4 of 4 (161 Views)
10-09-2013 02:05 PM in reply to: matt.worland
Glad to hear that, friend
Cheers :smileyhappy:
Oleg
