Thanks for your reply, Mark.
Just to be clear, I didn't want acad's plotstamp. I need to access each sheet as its plotted. I found some other threads on the PUBLISH command and sheet sets, but none dealt with accessing each sheet. The PUBLISH command may not use a saved sheet set, so I need to access the live one that is being published before and after the sheet gets plotted.
When you say "stamps a drawing", are you talking about the PLOT command? I'm not clear that what you did works with the PUBLISH command, stamping all sheets in the set. I have a vba solution that watches the PLOT command. However, what you describe sounds very similar to what I want to do, only with a block, not text. I'll also add some logging and configuration capability. What object's did you use?
Ed
How to
post your code.
