.NET
add popup menu to autocad (cuisamp sample)
1 REPLY 1
base2
1071 Views, 1 Reply
Hi
I try to use cuisamp sample from the .net samples.
I change the reference with correct reference in the autocad 2009 folder.
When I use netload to load cuisamp.dll autocad show this message in command line:
Error: Default AutoCAD Workspaces not found!
The cuisamp.dll is loaded, and if I run "addmenu" command not new menù is added on the main autocad menu.
Why?
thank you very much.
1 REPLY 1
filippobottega
in reply to: base2
In "public class CUIStartup : IExtensionApplication" you have to change:
const String ACADDEFAULT = "AutoCAD Default";
const String ACADCLASSIC = "AutoCAD Classic";
with workplace's names of your Autocad installation. Probably you are using a language other than English.
Best regards,
Filippo Bottega.
”Boost
