Hi
I try to use cuisamp sample from the .net samples.
I change the reference with correct reference in the autocad 2009 folder.
When I use netload to load cuisamp.dll autocad show this message in command line:
Error: Default AutoCAD Workspaces not found!
The cuisamp.dll is loaded, and if I run "addmenu" command not new menù is added on the main autocad menu.
Why?
thank you very much.
