How do I add a new Pagesetup in VB.NET?
I know I need the PlotSettings class
and I add it to the Drawing database.
Can someone get me started with the code and/or correct objecst?
This is copying one from another drawing but shows basic idea.
You add it to PlotSettingsDictionary
Database.PlotSettingsDictionaryId----to get DictionaryID
You can add to dictionary using the-----PlotSettings.AddToPlotSettingsDictionary
Public Const PLOTSETTINGSFILE As String = "C:\Users\Jeff\Desktop\PlotDrawing.dwg" <CommandMethod("AddPlotSetting")> _ Public Sub AddPlotSetting() Dim CurrentDatabase As Database = HostApplicationServices.WorkingDatabase Dim SourceDatabase As New Database(False, True) SourceDatabase.ReadDwgFile(PLOTSETTINGSFILE, FileOpenMode.OpenForReadAndAllShare, True, "") Using currentTransaction As Transaction = CurrentDatabase.TransactionManager.StartTransaction Using sourceTransaction As Transaction = SourceDatabase.TransactionManager.StartTransaction Dim sourcePlotDic As DBDictionary = SourceDatabase.PlotSettingsDictionaryId.GetObject(OpenMode.ForRead) Dim objID As ObjectId If sourcePlotDic.Contains("HCS PDF") Then objID = sourcePlotDic.GetAt("HCS PDF") Dim pl As PlotSettings = objID.GetObject(OpenMode.ForRead) Dim cpl As New PlotSettings(False) cpl.CopyFrom(pl) cpl.AddToPlotSettingsDictionary(CurrentDatabase) Dim bt As BlockTable = CurrentDatabase.BlockTableId.GetObject(OpenMode.ForRead) Dim btr As BlockTableRecord = bt(BlockTableRecord.PaperSpace).GetObject(OpenMode.ForRead) Dim lytobjID As ObjectId = btr.LayoutId.GetObject(OpenMode.ForRead).ObjectId Dim lytps As PlotSettings = lytobjID.GetObject(OpenMode.ForWrite) lytps.CopyFrom(cpl) End If currentTransaction.Commit() End Using End Using End Sub
For Plot offsets do I need to use the .SetPlotOrigin and use math to calculate the desired origin point for the lower left hand corner of the paper?
Oh and does the PlotSettingsValidator.SetClosestMediaName Method
... work better than the SetCanonicalMediaName....? (This is probably obvious.... but just checking)
Cause I'm thinking it would since I'm querying and excel spreadsheet with all our plot settings and then importing them into the pagesetup function.
I think this would probably help as our CanonicalMediaNames vary from printer to printer.
And we several different users using various printers... So less variables just need paper size 11x17, 8.5x11, etc...
Here's what I've got so far...
<CommandMethod("AddPlotSetting")> _ Public Sub AddPlotSetting(ByVal strPageSetupName As String, _ ByVal strconfigname As String, _ ByVal strpaperdisplayname As String, _ ByVal strdrivercanonicalmedianame As String, _ ByVal dblpaperwidth As String, _ ByVal dblpaperheight As String, _ ByVal isplotstyles As Boolean, _ ByVal strctbfilename As String, _ ByVal intPlotRotation As PlotRotation, _ ByVal intplottype As Integer, _ ByVal intstandardscale As Integer, _ ByVal isplotcentered As Boolean, _ ByVal dblxoffset As Double, _ ByVal dblyoffset As Double, _ ByVal ismodelorlayout As Boolean, _ Optional ByVal iscurrentsetup As Boolean = False) Dim s_PlotSettingsFile As String = "c:\acad.dwg" Dim s_MediaName As String = "11 x 17" Dim s_PlotDeviceName As String = "\\rdops1\RDO0071" Dim s_StyleSheetName As String = "Monochrome.ctb" Dim CurrentDatabase As Database = HostApplicationServices.WorkingDatabase Dim SourceDatabase As New Database(False, True) SourceDatabase.ReadDwgFile(s_PlotSettingsFile, FileOpenMode.OpenForReadAndAllShare, True, "") Using currentTransaction As Transaction = CurrentDatabase.TransactionManager.StartTransaction Using sourceTransaction As Transaction = SourceDatabase.TransactionManager.StartTransaction 'Dim sourcePlotDic As DBDictionary = SourceDatabase.PlotSettingsDictionaryId.GetObject(OpenMode.ForRead) 'Dim objID As ObjectId 'If sourcePlotDic.Contains("HCS PDF") Then ' objID = sourcePlotDic.GetAt("HCS PDF") '' Reference the Layout Manager Dim acLayoutMgr As LayoutManager acLayoutMgr = LayoutManager.Current '' Get the current layout Dim acLayout As Layout acLayout = currentTransaction.GetObject(acLayoutMgr.GetLayoutId(acLayoutMgr.CurrentLayout), _ OpenMode.ForRead) Dim pl As PlotSettings = New PlotSettings(acLayout.ModelType) 'Test Code Here 'Dim acPlSet As PlotSettings = New PlotSettings(acLayout.ModelType) 'Dim cpl As New PlotSettings(False) 'cpl.CopyFrom(pl) 'Update the Plot Settings Object 'Create PlotSettingsValidator Dim psv As PlotSettingsValidator = PlotSettingsValidator.Current 'Set the PageSetup Name psv.SetPlotViewName(pl, strPageSetupName) 'Set Plot Type psv.SetPlotType(pl, Autodesk.AutoCAD.DatabaseServices.PlotType.Extents) 'set plot scale psv.SetUseStandardScale(pl, True) psv.SetStdScaleType(pl, StdScaleType.ScaleToFit) psv.SetStdScale(pl, 0.0) 'Center the plot psv.SetPlotCentered(pl, True) 'Rotation psv.SetPlotRotation(pl, PlotRotation.Degrees000) 'Set Media Size psv.SetCanonicalMediaName(pl, s_MediaName) psv.SetCurrentStyleSheet(pl, s_StyleSheetName) '' Set the plot device to use psv.SetPlotConfigurationName(pl, s_PlotDeviceName, s_MediaName) 'Make Default PageSetup Yes/No? psv.SetDefaultPlotConfig(pl) 'Add to Plot Settings to Drawing Database pl.AddToPlotSettingsDictionary(CurrentDatabase) 'Dim bt As BlockTable = CurrentDatabase.BlockTableId.GetObject(OpenMode.ForRead) 'Dim btr As BlockTableRecord = bt(BlockTableRecord.PaperSpace).GetObject(OpenMode.ForRead) 'Dim lytobjID As ObjectId = btr.LayoutId.GetObject(OpenMode.ForRead).ObjectId 'Dim lytps As PlotSettings = lytobjID.GetObject(OpenMode.ForWrite) 'lytps.CopyFrom(cpl) 'End If currentTransaction.Commit() End Using End Using End Sub
