.NET
Active Contributor
0 Kudos
Post 1 of 8
Add many paths into loader key
353 Views, 7 Replies
01-02-2014 01:47 AM
Hi everybody,
I try to add some paths into registry value as picture:
Is there any way to do this?
Thanks for any help.
30 Kudos
Post 2 of 8
Re: Add many paths into loader key
01-02-2014 05:05 AM in reply to: xdbk07
I am afraid that multipath is not valid for 'LOADER' key. Better to create individual key for test2.dll
ADN Support Specialist
67 Kudos
Post 3 of 8
01-02-2014 09:44 AM in reply to: xdbk07
The usual way to do this is to create a 'loader DLL' that you set the demand load registry keys for. This loader DLL then takes care of loading any other required modules. For AutoCAD 2012 and above you should also look at the AutoLoader feature as a simple way to define demand load settings for your plugins.
Cheers,
Stephen Preston
Autodesk Developer Network
Active Contributor
0 Kudos
Post 4 of 8
01-02-2014 05:22 PM in reply to: xdbk07
Thanks for the comments. But I have many dll files, so I don't want to create many keys in registry.
Hi Stephen,
Can you tell more clearly or provide any links to learn?
Valued Mentor
53 Kudos
Post 5 of 8
01-02-2014 07:27 PM in reply to: xdbk07
As Stephen mentioned AutoLoader and a "Loader dll" I use AutoLoader to load a assembly that has no other references other than AutoCAD & BCL.
It just knows to find a file in same location that contains paths to network locations which contains another file for instructions.
The instructions tell it to copy, copy if file is newer, delete, include subdirectories, etc..... files inside its .bundle folder,
and load any assemblies, cui, etc... that needs to be loaded.
Also update the file used to find its location if needed to move.
You can also find your answers @ TheSwamp
67 Kudos
Post 6 of 8
01-03-2014 10:21 AM in reply to: xdbk07
The handout for this AU class is probably a good starting point - https://events.au.autodesk.com/connect/sessionDetail.ww?SESSION_ID=2142. Otherwise, search for 'Autoloader' on the ADN DevBlog, Kean's Through the Interface blog, this forum, or TheSwamp.
Cheers,
Stephen Preston
Active Contributor
0 Kudos
Post 7 of 8
01-05-2014 05:07 PM in reply to: StephenPreston
Thank Stephen, but I cannot access to provided link.
1,211 Kudos
Post 8 of 8
01-06-2014 12:25 AM in reply to: xdbk07
The point on the end is too much, should be:
- alfred -
Alfred NESWADBA
