.NET
JONTHEPOPE
Message 1 of 9 (168 Views)
add linetypes to layers
168 Views, 8 Replies
07-17-2014 07:45 AM
How do I add linetype to an array of layers
//line types are loaded but how do I assign them to a certain name
        '' Open the Layer table for read
        Dim acLyrTbl As LayerTable
        acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, _
                                     OpenMode.ForRead)
        '' Define an array of layer names
        Dim sLayerNames(2) As String
        sLayerNames(0) = "ACIRed"
        sLayerNames(1) = "TrueBlue"
        sLayerNames(2) = "ColorBookYellow"
        '' Define an array of colors for the layers
        Dim acColors(2) As Color
        acColors(0) = Color.FromColorIndex(ColorMethod.ByAci, 1)
        acColors(1) = Color.FromRgb(23, 54, 232)
        acColors(2) = Color.FromNames("PANTONE Yellow 0131 C", _
                                      "PANTONE(R) pastel coated")
        Dim nCnt As Integer = 0
        '' Add or change each layer in the drawing
        For Each sLayerName As String In sLayerNames
            If acLyrTbl.Has(sLayerName) = False Then
                Using acLyrTblRec As LayerTableRecord = New LayerTableRecord()
                    '' Assign the layer a name
                    acLyrTblRec.Name = sLayerName
                    '' Upgrade the Layer table for write
                    If acLyrTbl.IsWriteEnabled = False Then acLyrTbl.UpgradeOpen()
                    '' Append the new layer to the Layer table and the transaction
                    acLyrTbl.Add(acLyrTblRec)
                    acTrans.AddNewlyCreatedDBObject(acLyrTblRec, True)
                    '' Set the color of the layer
                    acLyrTblRec.Color = acColors(nCnt)
                End Using
            Else
                '' Open the layer if it already exists for write
                Dim acLyrTblRec As LayerTableRecord = acTrans.GetObject(acLyrTbl(sLayerName), _
        OpenMode.ForWrite)
            End If
            nCnt = nCnt + 1
        Next
        '' Save the changes and dispose of the transaction
        acTrans.Commit()
    End Using
End Sub
Well, not seeing your whole code and not knowing the drawing you use to test your code, it is not easier to go through your partial code to identify what is wrong, than just write some code to show you how it works.
Have you step through your code in debugging, which should lead you easily to where the exception occurs and you can usually find out what is the reason.
Anyway, here is some simple code that set linetype of a layer ("Layer1", if not exists, create it; and its linetype is "Continuous" by default) from to "Hidden" (assume this linetype has already been loaded into the current drawing database):
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using CadApp = Autodesk.AutoCAD.ApplicationServices.Application;
[assembly: CommandClass(typeof(SetLayerLineType.MyCadCommands))]
namespace SetLayerLineType
public class MyCadCommands
[CommandMethod("SetLT")]
public void SetLayerLineType()
Document dwg = CadApp.DocumentManager.MdiActiveDocument;
if (dwg == null) return;
Editor ed = dwg.Editor;
try
SetLayerLineType(dwg, "layer1", "Hidden");
catch (System.Exception ex)
ed.WriteMessage(
"\nError: {0}\n{1}", ex.Message, ex.StackTrace);
finally
Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt();
private void SetLayerLineType(
Document dwg, string layerName, string lineTypeName)
using (Transaction tran =
dwg.Database.TransactionManager.StartTransaction())
LayerTable layerTable = (LayerTable)tran.GetObject(
dwg.Database.LayerTableId, OpenMode.ForRead);
LinetypeTable lineTable = (LinetypeTable)tran.GetObject(
dwg.Database.LinetypeTableId, OpenMode.ForRead);
ObjectId lineTypeId = ObjectId.Null;
if (lineTable.Has(lineTypeName))
lineTypeId = lineTable[lineTypeName];
LayerTableRecord layer;
if (layerTable.Has(layerName))
layer = (LayerTableRecord)tran.GetObject(
layerTable[layerName], OpenMode.ForRead);
LinetypeTableRecord lineType=(LinetypeTableRecord)
tran.GetObject(lineTypeId,OpenMode.ForRead);
dwg.Editor.WriteMessage(
"\nLine type of existing layer \"{0}\" is {1}",
layer.Name, lineType.Name);
//set to desired linetype
if (!lineTypeId.IsNull)
layer.UpgradeOpen();
layer.LinetypeObjectId = lineTypeId;
else
layer = new LayerTableRecord();
layer.Name = layerName;
layerTable.UpgradeOpen();
layerTable.Add(layer);
tran.AddNewlyCreatedDBObject(layer, true);
//Before a new layer is commited in the transaction,
//its LineTypeObjectId is Null, unless being assigned explicitly
//However, if no linetypeObjectId is assigned, the new layer would
//get "Continuous" line type upon transaction committing
"\nnewly created layer \"{0}\" with linetypeID->{1}",
layerName,
layer.LinetypeObjectId.ToString());
//Set to desired linetype
//Prove linetype has been set to the layer
LinetypeTableRecord lt = (LinetypeTableRecord)tran.GetObject(
layer.LinetypeObjectId, OpenMode.ForRead);
"\nLineType has been set to {0}", lt.Name);
tran.Commit();
norman.yuan
Message 2 of 9 (156 Views)
Re: add linetypes to layers
07-17-2014 09:35 AM in reply to: JONTHEPOPE
Just like how you set layer's color, you set layer's linetype by assign LayerTableRecord.LineTypeObjectId property a valid ObjectId that points a LineTypeTableRecord.
Database.LineTypeTableId -> LineTypeTable -> LineTypeTable[line type name]
JONTHEPOPE
Message 3 of 9 (153 Views)
07-17-2014 09:58 AM in reply to: norman.yuan
I'm confused can I set a line type to a layer?
I don't really know how to put my linetype on to my layer.
I tried your example but I don't understand fully how to get it to work.
// Save the changes and dispose of the transaction
                            acTrans.Commit();
              // Start a transaction
            using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
                // Open the Layer table for read
        LayerTable acLyrTbl;
                                        OpenMode.ForRead) as LayerTable;
            string getnewline = "M-ANNO-TEXT-NEWW";
            LayerTableRecord acLyrTblRec;
                if (acLyrTbl.Has(getnewline) == true)
                    acLyrTblRec = acTrans.GetObject(acLyrTbl[getnewline], OpenMode.ForRead) as LayerTableRecord;
                LinetypeTable acLinTbl;
                acLinTbl = acTrans.GetObject(acCurDb.LinetypeTableId,
                                            OpenMode.ForRead) as LinetypeTable;
                if (acLinTbl.Has("RETURN") == true)
                    // Upgrade the Layer Table Record for write
                    acLyrTblRec.UpgradeOpen();
                    // Set the linetype for the layer
                    acLyrTblRec.LinetypeObjectId = acLinTbl["RETURN"]; }
                acTrans.Commit(); } }
norman.yuan
Message 4 of 9 (146 Views)
07-17-2014 10:09 AM in reply to: JONTHEPOPE
You code looks OK to me and it should change the linetype of layer "M-ANNO-TEXT-NEWW" to a linetype called "RETURN", if the "RETURN" line type has been loaded into the drawing previously. Have you tried to run this small piece code to see the result?
JONTHEPOPE
Message 5 of 9 (142 Views)
07-17-2014 12:15 PM in reply to: norman.yuan
the line type is loaded and I ran the code
1 error message
Use of unassigned loacl variable 'acLyrTblRec'
norman.yuan
Message 6 of 9 (135 Views)
07-17-2014 12:42 PM in reply to: JONTHEPOPE
If you look at your code carefully, you should realize that the drawing where you were trying your code does not have a layer called "M-ANNO-TEXT-NEWW". That is, int this line of code:
the line inside the {...} is not executed, thus, acLyrTblRec is "unassigned". The code following this "if...." should have been placed inside this "if...." statement, so the exception can be avoided.
JONTHEPOPE
Message 7 of 9 (100 Views)
07-18-2014 11:21 AM in reply to: norman.yuan
here's my progress so far still doesn't work
        string[] sLayerNames = new string[3];
        sLayerNames[0] = "ACIRed";
        sLayerNames[1] = "TrueBlue";
        sLayerNames[2] = "ColorBookYellow";
        Color[] acColors = new Color[3];
        acColors[0] = Color.FromColorIndex(ColorMethod.ByAci, 1);
        acColors[1] = Color.FromRgb(23, 54, 232);
        acColors[2] = Color.FromNames("PANTONE Yellow 0131 C",
                                        "PANTONE(R) pastel coated");
        int nCnt = 0;
        foreach (string sLayerName in sLayerNames)
            if (acLyrTbl.Has(sLayerName) == false)
                using (LayerTableRecord acLyrTblRec = new LayerTableRecord())
                    acLyrTblRec.Name = sLayerName;
                    if (acLyrTbl.IsWriteEnabled == false) acLyrTbl.UpgradeOpen();
                    acLyrTbl.Add(acLyrTblRec);
                    acTrans.AddNewlyCreatedDBObject(acLyrTblRec, true);
                    if (acLinTbl.Has("Center") == true)
                        acLyrTblRec.LinetypeObjectId = acLinTbl["Center"];
                    acLyrTblRec.Color = acColors[nCnt];
            else
                LayerTableRecord acLyrTblRec = acTrans.GetObject(acLyrTbl[sLayerName],
        OpenMode.ForWrite) as LayerTableRecord;
            nCnt = nCnt + 1;
        acTrans.Commit();
norman.yuan
Message 8 of 9 (91 Views)
07-18-2014 12:47 PM in reply to: JONTHEPOPE
            try
                ed.WriteMessage(
            finally
                else
                        layerName,
                tran.Commit();
JONTHEPOPE
Message 9 of 9 (85 Views)
07-18-2014 01:38 PM in reply to: norman.yuan
Thanks for your help Norman I see the error in my ways it works now!:smileyhappy:
