.NET
Add Linetype to Layer
14 REPLIES 14
Message 1 of 15
676 Views, 14 Replies
I have a sub that creates a layer from selected database, I can't seem to find the variables needed to add a linetype here's the code;
Dim layerId As ObjectId 'the return value for this function
Dim db As Database = HostApplicationServices.WorkingDatabase
Dim trans As Transaction = db.TransactionManager.StartTransaction()
Try
'Get the layer table first, open for read as it may already be there
Dim lt As LayerTable = trans.GetObject(db.LayerTableId, OpenMode.ForRead)
Dim ltdb As LinetypeTable = trans.GetObject(db.LinetypeTableId, OpenMode.ForRead)
'Check if Layer exists...
If lt.Has(layern) Then
layerId = lt.Item(layern)
Else
'If not, create the layer here.
Dim ltr As LayerTableRecord = New LayerTableRecord()
ltr.Name = layern 'Set the layer name
ltr.Color = Color.FromColorIndex(ColorMethod.ByAci, PENN)
ltr.Description = DES
Dim ltrid As LinetypeTableRecord = New LinetypeTableRecord()
'Lost at this point
' it doesn't exist so add it, but first upgrade the open to write
lt.UpgradeOpen()
layerId = lt.Add(ltr)
trans.AddNewlyCreatedDBObject(ltr, True)
trans.Commit()
14 REPLIES 14
Message 2 of 15
Mikko
You need the objectid of the linetype, something like this:
Dim hiddenlineId As ObjectId
Dim lt As LayerTable = t.GetObject(db.LayerTableId, OpenMode.ForWrite)
If lt.Has(LayName) Then
layerId = lt.Item(LayName)
Else
Call LoadLineTypes()
ltr.Name = LayName
ltr.LinetypeObjectId = hiddenlineId
t.AddNewlyCreatedDBObject(ltr, True)
Sub LoadLineTypes()
Dim t As Transaction = db.TransactionManager.StartTransaction()
Try
db.LoadLineTypeFile("Hidden", "acad.lin")
Catch ex As Exception
End Try
Dim tbl As LinetypeTable = t.GetObject(db.LinetypeTableId, OpenMode.ForRead, False)
Try
hiddenlineId = tbl("Hidden")
End Try
t.Commit()
t.Dispose()
End Sub
Message 3 of 15
This is great, but I'm working within a loop which pulls a linetype from the dataset and saves it to string, would i Place the sub load line type's before to loop or in it.
I like the ideal of making the 'Dim hiddenlineId As ObjectId' as I can pass the varible to this.
Here's The entire Sub
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim layern As String = ""
Dim PENN As String = ""
Dim DES As String = ""
'Dim LTY As String = ""
Dim obj As System.Data.DataRowView
Dim obj1 As System.Data.DataRowView
Dim obj2 As System.Data.DataRowView
Dim obj3 As System.Data.DataRowView
For Each obj In ListBox1.SelectedItems
layern = CType(obj.Item("Layer"), String)
DES = CType(obj.Item("DESCRIPTION"), String)
PENN = CType(obj.Item("PEN"), String)
'LTY = CType(obj.Item("LINETYPE"), String)
Try
Else
'Dim ltrid As LinetypeTableRecord = New LinetypeTableRecord()
'Lost at this point
lt.UpgradeOpen()
trans.Commit()
Catch ex As System.Exception
MsgBox("Error in CreateLayer Command" + ex.Message)
Finally
trans.Dispose()
End Try
Next
Me.Close()
End Sub
Message 4 of 15
Mikko
Use a function to return your linetypeId as the variable you need to set.
Function LineTypeId(ByVal typeline As String) As ObjectId
db.LoadLineTypeFile(typeline, "acad.lin")
LineTypeId = tbl(typeline)
t.Commit()
t.Dispose()
End Function
Try
Dim lt As LayerTable = trans.GetObject(db.LayerTableId, OpenMode.ForWrite)
Else
ltr.LinetypeObjectId = LineTypeId(LTY)
t.Commit()
Catch ex As System Exception
Finally
trans.Dispose()
End Try Message was edited by: Mikko
Message 5 of 15
Making it a function Public/private creates a fatal error in AutoCAD..
Message 6 of 15
Error Is undefined Linetype
Here's the code;
Public Function LineTypeId(ByVal typeline As String) As ObjectId
t.Commit()
t.Dispose()
End Function
Try
Else
trans.Commit()
Finally
trans.Dispose()
End Try
Next
Me.Close()
End Sub
Message 7 of 15
Mikko
Is the linetype your pulling from your dataset an AutoCAD LineType?
Here is a quick 20 minute demo... had to try this out myself and a dwg
that was saved from inventor
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Colors
Imports Autodesk.AutoCAD.EditorInput
Public Class Class1
Dim visibleId As ObjectId
Dim hiddenId As ObjectId
Dim centerId As ObjectId
Dim dimensionId As ObjectId
Dim partId As ObjectId
Dim part2Id As ObjectId
Dim movementId As ObjectId
Dim interfaceequipId As ObjectId
Dim interfaceequip2Id As ObjectId
Dim balloonId As ObjectId
<CommandMethod("ChangeLayers", CommandFlags.Session)> _
Public Sub ChangeLayers()
Dim foundFile As String = ""
Dim fbd As New Windows.Forms.FolderBrowserDialog
Dim ThisOne As String = ""
If fbd.ShowDialog() = Windows.Forms.DialogResult.OK Then
ThisOne = fbd.SelectedPath
Else
MsgBox("You must select a Folder")
Exit Sub
Dim docLock As DocumentLock
For Each foundFile In My.Computer.FileSystem.GetFiles(ThisOne, FileIO.SearchOption.SearchAllSubDirectories, "*.dwg")
Dim docs As Autodesk.AutoCAD.ApplicationServices.DocumentCollection
docs = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
Dim doc As Autodesk.AutoCAD.ApplicationServices.Document = docs.Open(foundFile, False)
docLock = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument()
Call SetMyLayers()
Call This2That_Layers()
docLock.Dispose()
doc.CloseAndSave(foundFile)
Next
End Sub
Public Sub SetMyLayers()
visibleId = CheckForLayer("my01", 7, "Continuous")
hiddenId = CheckForLayer("my02", 2, "Hidden")
centerId = CheckForLayer("my03", 6, "Center")
dimensionId = CheckForLayer("my04", 3, "Continuous")
partId = CheckForLayer("my05", 5, "Phantom")
part2Id = CheckForLayer("my06", 1, "Phantom")
movementId = CheckForLayer("my07", 4, "Phantom2")
interfaceequipId = CheckForLayer("my08", 30, "Phantom")
interfaceequip2Id = CheckForLayer("my09", 201, "Phantom")
balloonId = CheckForLayer("BallnStock", 146, "Continuous")
End Sub
Public Function CheckForLayer(ByVal namLay As String, ByVal colLay As Integer, ByVal typLin As String) As ObjectId
If lt.Has(namLay) Then
layerId = lt.Item(namLay)
Else
ltr.Name = namLay
ltr.Color = Color.FromColorIndex(ColorMethod.ByAci, colLay)
If typLin <> "Continuous" Then ltr.LinetypeObjectId = CheckForLineType(typLin)
t.Commit()
t.Dispose()
Return layerId
End Function
Public Function CheckForLineType(ByVal typeline As String) As ObjectId
Dim linetypeId As ObjectId
If tbl.Has(typeline) Then
linetypeId = tbl(typeline)
Else
t.Commit()
t.Dispose()
Return linetypeId
End Function
Sub This2That_Layers()
Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
Dim psr As PromptSelectionResult
Dim idArray() As ObjectId
Dim objId As ObjectId
Dim ent As Entity
Try
Dim filterfor() As TypedValue = {New TypedValue(8, "Hidden (ANSI)")}
Dim sf As SelectionFilter = New SelectionFilter(filterfor)
psr = ed.SelectAll(sf)
If psr.Status = PromptStatus.OK Then
Dim ss As Autodesk.AutoCAD.EditorInput.SelectionSet = psr.Value
idArray = ss.GetObjectIds()
For Each objId In idArray
ent = t.GetObject(objId, OpenMode.ForWrite, False)
ent.LayerId = hiddenId
ent.Color = Color.FromColorIndex(ColorMethod.ByLayer, 256)
ent.Linetype = SymbolUtilityServices.LinetypeByLayerName()
Next objId
Finally
psr = Nothing
idArray = Nothing
objId = Nothing
ent = Nothing
End Try
t.Commit()
t.Dispose()
End Sub
End Class
Message 8 of 15
I can get the function to work but I get this error after it creates the layer."Error in createLayer CommandekeyNot Found"..
code;
Private Sub CREATDIALOG_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
'TODO: This line of code loads data into the 'PWGSCDataSet.Selected_Layers' table. You can move, or remove it, as needed.
Me.Selected_LayersTableAdapter.Fill(Me.PWGSCDataSet.Selected_Layers)
Dim x As Integer
' Loop through all items the ListBox.
For x = 0 To ListBox1.Items.Count - 1
' Select all items that are not selected.
ListBox1.SetSelected(x, True)
ListBox2.SetSelected(x, True)
ListBox3.SetSelected(x, True)
ListBox4.SetSelected(x, True)
Next x
db.LoadLineTypeFile("*", "acad.lin")
End Sub
Private Sub Button2_Click(ByVal sender As System.Object,
t.Commit()
t.Dispose()
End Function
Try
'Dim ltdb As LinetypeTable = trans.GetObject(db.LinetypeTableId, OpenMode.ForRead)
Else
'Set the layer name
ltr.Name = layern
trans.Commit()
Finally
trans.Dispose()
End Try
Next
Me.Close()
End Sub
Message 9 of 15
It looks like it's failling on to many layers / it will make up to 27 then error..Any ideas how to stop this?
Message 10 of 15
I appreciate your help, I have made the app similar to your posting using functions, Unfourtunstely I still runing into this creation error, without line type i can creat an infinate number of layers. With linetype it error on 79 layers and crashes autocad eventually. I think this has to do with the dispose commands. Just a guese..
Message 11 of 15
Mikko
I added a loop to SetMyLayers that adds hundreds of layers.
Doesn't seem to have any problem.
For i As Integer = 90 To 1 Step -1
visibleId = CheckForLayer("my01" & i.ToString, 7, "Continuous")
hiddenId = CheckForLayer("my02" & i.ToString, 2, "Hidden")
centerId = CheckForLayer("my03" & i.ToString, 6, "Center")
dimensionId = CheckForLayer("my04" & i.ToString, 3, "Continuous")
partId = CheckForLayer("my05" & i.ToString, 5, "Phantom")
part2Id = CheckForLayer("my06" & i.ToString, 1, "Phantom")
movementId = CheckForLayer("my07" & i.ToString, 4, "Phantom2")
interfaceequipId = CheckForLayer("my08" & i.ToString, 30, "Phantom")
interfaceequip2Id = CheckForLayer("my09" & i.ToString, 201, "Phantom")
balloonId = CheckForLayer("BallnStock" & i.ToString, 146, "Continuous")
Next
End Sub
Message 12 of 15
Could it be that I'm pulling the variables from a dataset?
Message 13 of 15
Mikko
It shouldn't. I tried it against a Web Service with the table in SQL Sever with no problems.
Dim ws As New longhorn.Service
Dim dt As System.Data.DataTable = ws.Layers.Tables(0)
Dim dv As New DataView(dt)
Dim drv As DataRowView
For Each drv In dv
Select Case drv("LayerDescription")
Case "Visible"
visibleId = CheckForLayer(drv("LayerName"), drv("LayerColor"), drv("LayerLinetype"))
Case "Center"
centerId = CheckForLayer(drv("LayerName"), drv("LayerColor"), drv("LayerLinetype"))
Case "Dimension"
dimensionId = CheckForLayer(drv("LayerName"), drv("LayerColor"), drv("LayerLinetype"))
Case "Hidden"
hiddenId = CheckForLayer(drv("LayerName"), drv("LayerColor"), drv("LayerLinetype"))
Case "Main Part"
partId = CheckForLayer(drv("LayerName"), drv("LayerColor"), drv("LayerLinetype"))
Case "Secondary Part"
part2Id = CheckForLayer(drv("LayerName"), drv("LayerColor"), drv("LayerLinetype"))
Case "Motion"
movementId = CheckForLayer(drv("LayerName"), drv("LayerColor"), drv("LayerLinetype"))
Case "Interface1 Equipment"
interfaceequipId = CheckForLayer(drv("LayerName"), drv("LayerColor"), drv("LayerLinetype"))
Case "Interface2 Equipment"
interfaceequip2Id = CheckForLayer(drv("LayerName"), drv("LayerColor"), drv("LayerLinetype"))
Case "Ball-n-Stock"
balloonId = CheckForLayer(drv("LayerName"), drv("LayerColor"), drv("LayerLinetype"))
Case Else
End Select
Next
End Sub
Message 14 of 15
Thanks for your continued assistance, I'm posting the refined code if you can see anything that jumps out as wrong please let me know, I going to try refining some more?
Message 15 of 15
I solved It, After all the searching I went back to the dataset and found some spelling errors in the linetype idenification.. I feel so stupid..Thanks for all your help..
”Boost
