.NET
Active Member
vryarbe
Message 1 of 11 (1,088 Views)
Add Layer Description to Layer Dropdown list
1088 Views, 10 Replies
03-22-2010 03:38 PM
Is there a way in .net to add the layer description field (viewable in the Layer Properties Manager menu) to the layer dropdown list? Our designers want to see this information without opening the Layer Properties menu.
Thanks!
Active Contributor
fyathyrio8
Message 2 of 11 (1,088 Views)
Re: Add Layer Description to Layer Dropdown list
03-23-2010 02:52 PM in reply to: vryarbe
LayerTableRecord has a Description property. I'm not sure if this is what's used in the layers dropdown, but it might be worth a shot.
*Michael Robertson
Message 3 of 11 (1,088 Views)
03-24-2010 05:32 AM in reply to: vryarbe
Hello fyathyrio8,
LayerTableRecord.Description is the property you want to set for the description
that shows up in the Layer dialog.
*Tony Tanzillo
Message 4 of 11 (1,088 Views)
03-24-2010 05:55 AM in reply to: vryarbe
There's several layer controls.
One is on the Ribbon and another is on the layer toolbar.
Which are you using?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6358774@discussion.autodesk.com...
Thanks!
*Tony Tanzillo
Message 5 of 11 (1,088 Views)
03-24-2010 06:05 AM in reply to: vryarbe
The OP asked how to get the description to show up in the layer dropdown.
Do you have a suggestion for that?
"Michael Robertson" wrote in message
news:6359834@discussion.autodesk.com...
Hello fyathyrio8,
Active Member
vryarbe
Message 6 of 11 (1,088 Views)
03-24-2010 02:34 PM in reply to: vryarbe
We are using the Classic AutoCAD layer dropdown,
(see attachment). Our designers have requested the
ability to view the layer description next to the layer
name to help them know which layer to choose.
Normally, I'd define the layer name to provide a
hint, but these files all have generic layer names
for post-processing reasons.
Vic Yarberry
*Owen Wengerd
Message 7 of 11 (1,088 Views)
03-24-2010 03:59 PM in reply to: vryarbe
Your only option is to create a standalone custom layer control, as there is
no way to customize the built in layer control. There have been some pretty
impressive third party layering systems built over the years, so you may
want to spend some time researching how others have solved the problem.
Owen Wengerd
President, ManuSoft <>
VP Americas, CADLock, Inc. <>
wrote in message
news:6360360@discussion.autodesk.com...
> Thanks,
> Vic Yarberry
*Tony Tanzillo
Message 8 of 11 (1,088 Views)
03-24-2010 05:11 PM in reply to: vryarbe
In that case, I'm afraid you're out of luck, because
the toolbar layer dropdown is not customizable in
any way, short of subclassing it and completely
replicating item painting.
OTOH, it took me about 5 minutes to modify some
code I wrote for extending AutoCAD Data Extraction,
to make it happen with the layer dropdown on the
ribbon (see the attached screen grab), and you can
get it here:
http://www.caddzone.com/LayerHelper.zip
wrote in message news:6360360@discussion.autodesk.com...
Vic Yarberry
Valued Mentor
ralstogj
Message 9 of 11 (605 Views)
01-25-2012 02:02 AM in reply to: vryarbe
Hi
Did any one download Tony's example code who could post it here or email it to me as the link no longer works and his site is not active anymore.:smileysad:
Regards
Justin Ralston
http://c3dxtreme.blogspot.com/
Distinguished Mentor
andrewpuller3811
Message 10 of 11 (561 Views)
01-29-2012 03:11 AM in reply to: ralstogj
The original as downloaded from tony's site.
If this fixed your issue, click on "Accept as Solution"
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
