.NET
Active Contributor
chikito1990
Message 1 of 6 (8,095 Views)
Add ellipse in drawing.
8095 Views, 5 Replies
08-05-2013 04:41 AM
Hi all,
I am trying to create a cylinder. To accomplish this I am creating two ellipses and two lines. After I try to insert them in the DWG dwaing I can see only the lines. Here is a code sniped so you can see what am i doing.
Double ellipseRadiusRatio = 0.4;
                Vector3d ellipseMajorAxis = new Vector3d(0.0, 1500.0, 0.0);
                Vector3d ellipseLeftCenter = new Vector3d(72541.7, 80198.5, 0.0);
                Vector3d ellipseRightCenter = new Vector3d(77145.7, 80173.6, 0.0);
                Ellipse leftEllipse = new Ellipse();
                leftEllipse.MajorAxis.Add(ellipseMajorAxis);
                leftEllipse.RadiusRatio = ellipseRadiusRatio;
                leftEllipse.Center.Add(ellipseLeftCenter);
                leftEllipse.StartAngle = 0;
                Ellipse rightEllipse = new Ellipse();
                rightEllipse.MajorAxis.Add(ellipseMajorAxis);
                rightEllipse.RadiusRatio = ellipseRadiusRatio;
                rightEllipse.Center.Add(ellipseRightCenter);
                rightEllipse.StartAngle = 0;
                Point3d ellipseTopStart = new Point3d(77154.7, 81673.6, 0.0);
                Point3d ellipseTopEnd = new Point3d(72541.7, 81698.5, 0.0);
                Point3d ellipseBottumStart = new Point3d(77154.7, 78673.6, 0.0);
                Point3d ellipseBottumEnd = new Point3d(72578.5, 78701.8, 0.0);
                Line ellipseTop = new Line(ellipseTopStart, ellipseTopEnd);
                Line ellipseButtom = new Line(ellipseBottumStart, ellipseBottumEnd);
                acBlkTblRec.AppendEntity(rightEllipse);
                acBlkTblRec.AppendEntity(leftEllipse);
                acBlkTblRec.AppendEntity(ellipseTop);
                acBlkTblRec.AppendEntity(ellipseButtom);
                acTrans.Commit();
 I hope you can see the problem.
Thnaks in advance!
Best regards,
Dimitar Georgiev
mzakiralam
Message 2 of 6 (8,083 Views)
Re: Add ellipse in drawing.
08-05-2013 05:28 AM in reply to: chikito1990
Try to add below lines before doing acTrans.commit():
acTrans.AddNewlyCreatedDBObject(rightEllipse, True)
acTrans.AddNewlyCreatedDBObject(leftEllipse, True)
acTrans.AddNewlyCreatedDBObject(ellipseTop, True)
acTrans.AddNewlyCreatedDBObject(ellipseBottom, True)
Active Contributor
chikito1990
Message 3 of 6 (8,079 Views)
08-05-2013 05:40 AM in reply to: mzakiralam
still the same result. I uploaded 2 pictures "result"  is the current pucture,  but i wnat to be like "result2" (ignore colors and extra elements)
mzakiralam
Message 4 of 6 (8,055 Views)
08-05-2013 07:15 AM in reply to: chikito1990
As I did not see your full code so I can't tell why it is going wrong. However, in below there are 2 links where drawing ellipse is involved. Try to compare your ellipse with those code:
http://forums.autodesk.com/t5/NET/How-can-I-use-a-graphic-ellipse-with-text-together/m-p/3806417/hig...
http://forums.autodesk.com/t5/NET/VB-NET-SET-METHOD-ON-ELLIPSE/td-p/2824426
Hallex
Message 5 of 6 (8,051 Views)
08-05-2013 07:22 AM in reply to: chikito1990
See also:
http://adndevblog.typepad.com/autocad/2012/05/creating-an-ellipse.html
mzakiralam
Message 6 of 6 (8,049 Views)
08-05-2013 07:25 AM in reply to: chikito1990
probably I understand the point that why ellipse drawing is not wokring.
"The way to create an ellipse is to use the constructor of ellipse class and pass the parameters." - I got this line from adndevblog.The way you try to draw ellipse is not valid. try to see below link. There you will get full code of how to create ellipse:
I hope this will solve your issue.
Regards
Zakir
