Show only
Search instead for
I'm trying to include data for a point within the XData of a leader (to compare against later to see if the object it's pointing to has been moved). -BUt I'm not having any luck adding the point data as a TypedValue. - I keep getting an "Invalid cast" exception.
Would someone tell me what I'm doing wrong?
-The ObjectARX lab samples gave me a hint; I was making it too hard - the value is set as a point, and stored that way (not by X, Y, Z)
Revised code attached.
