.NET
Add a line to .dwg
1 REPLY 1
172 Views, 1 Reply
Add a line to .dwg
I have been working on this program that is supposed to add a line to a .dwg. I am having trouble creating the line object. Attached is the source code if anyone wishes to look at it.
Thank you
1 REPLY 1
For starters, a line requires 2 2D points and your passing it an array of 3
Public Sub New(ByVal point1 As Autodesk.AutoCAD.Geometry.Point2d, ByVal
point2 As Autodesk.AutoCAD.Geometry.Point2d)
-- Mike
___________________________
Mike Tuersley
the trick is to realize that there is no spoon...
”Boost
