Hello Forum,
the following code gives me an eNotFromThisDocument error:
[LispFunction("MyFunction")] public ResultBuffer MyFunction(ResultBuffer rbParameter) { ... objDocument = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Open(strPath, false); if (!objDocument.IsReadOnly) { using (objDocumentLock = objDocument.LockDocument()) { Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument = objDocument; objDocument.Database.TileMode = true; // = eNotFromThisDocument. } objDocument.CloseAndSave(strPath); objDocument.Dispose(); } ... }
I think it is because the Editor does not get linked to the newly opened drawing. In other words, I can not change tilemode of objDocument, because the drawing from which I called this function is still the active/current drawing. How can I tell AutoCAD that objDocument should be the active/current drawing, so I can change the tilemode, and use Editor functionality, such as SendString()?
Thank you.
Solved by Alfred.NESWADBA. Go to Solution.
as a guess: in LISP you get lost if the document changed as LISP-code it runs document-based. If you start a LISP in A.DWG you can start to load B.DWG but the lisp-code will not continue in B.DWG.
That you load a drawing and make the this other drawing active within a LISP-function may be the source of the problem.
- alfred -
See if this works for yoy, tested on A2010
<code>
Document doc = acadApp.DocumentManager.MdiActiveDocument;
string strPath = .....;
using (DocumentLock objDocumentLock = doc.LockDocument())
Document objDocument = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Open(strPath, false);
using (DocumentLock pDocumentLock = objDocument.LockDocument())
Database pdb = HostApplicationServices.WorkingDatabase;
if (pdb.TileMode == true)
pdb.TileMode = false;
//Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("ctab", "Floor Plan");//debug only
return new ResultBuffer(new TypedValue((int)LispDataType.Nil));
</code>
