.NET
Distinguished Contributor
junoj
Message 1 of 4 (143 Views)
Acdbmgd versions compatibility issues
143 Views, 3 Replies
08-30-2013 08:38 AM
In one my codes I am using a property of an Editor [ ActiveViewportId ] and I am able to compile that when I reference the (acdbmgd, acmgd) from 2011 without any problems.
When I try to do the same for the 2008, I get an error stating that [ ‘ActiveViewportId’ is not a member of ‘Autodesk.AutoCAD.EditorInput.Editor’ ]
Do we as .net programmers have a remedy for situations like the one above? Can we import objects from one class library to another? I am just trying to find the best way on how someone would go about trying to make their code compatible across several versions of AutoCAD.
Thank you,
-J
*Expert Elite*
dgorsman
Message 2 of 4 (133 Views)
Re: Acdbmgd versions compatibility issues
08-30-2013 10:21 AM in reply to: junoj
Thats a pretty big jump between versions.  Later versions frequently include things which are not available in older versions, and there is nothing to be done about it aside from coding based on the most restrictive environment (forward compatibility is always easier).  Otherwise, you need to code specifically for the quirks and limitations of each version.
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
junoj
Message 3 of 4 (120 Views)
08-30-2013 12:33 PM in reply to: junoj
So with .NET one has to “compile their code” overtime a new version of CAD is issued. Because it appears that it’s not only backward incompatible but it’s also forward incompatible too.
I tried running my 2008 code in 2013 and it does not work.
I ask this because files like lisp and vba have been running on multi versions of CAD without any issues, and with .NET it’s less than 5 and the code needs amendments.
So how would one go about keeping track with their .NET code? Procedures, best practices; I would like to learn and adapt good habits. Any advice on this topic would be appreciated.
*Expert Elite*
_gile
Message 4 of 4 (104 Views)
08-31-2013 12:57 AM in reply to: junoj
There're very few forward compatibility issues with the .NET API, except the 2013 "big split".
I have many programs targeting the A2007 SDK (Framework 2.0) which work from A2007 to A2012 without any changes in the code nor need to new compilation, and which only needed a new compilation referencing A2013 assemblies to work with A2013-2014.
By my side, the only forward compatibility problem I encountered before 2013 was with abstract method Drawable.ViewportDraw() which changed to Drawable.SubViewportDraw() with A2010 (see here).
Gilles Chanteau
Post to the Community
New Post
Need installation help?
