.NET
Active Member
mbair
Message 1 of 5 (303 Views)
AcCoreConsole + OLE Object Printing
303 Views, 4 Replies
03-21-2013 03:18 AM
Is anyone having success printing OLE objects via AcCoreConsole?  When printing from AutoCAD itself, I'm able to print OLE objects, but when using AcCoreConsole to print, OLE objects do not show up on the print.
ADN Support Specialist
Balaji_Ram
Message 2 of 5 (297 Views)
Re: AcCoreConsole + OLE Object Printing
03-21-2013 03:55 AM in reply to: mbair
This is a known behavior of AccoreConsole.exe.
Sorry, It cannot print OLE objects at present.
Balaji
Developer Technical Services
Autodesk Developer Network
odurier
Message 3 of 5 (173 Views)
08-26-2013 08:53 AM in reply to: Balaji_Ram
I tested on AutoCAD 2014 but it still does not work
Is expected soon?
Many of our customers generates pdf containing OLE objects via accoreconsole.exe
Do you have a solution?
Balaji_Ram
Message 4 of 5 (138 Views)
08-27-2013 09:30 PM in reply to: mbair
The request is being evaluated by our engineering team and I do not have information on when this might be made available. OLE has dependencies on the window handle and implementing it in AccoreConsole that does not have a UI of its own is likely to be a major implementation. So, this request is likely to be evaluated by our engineering team as a feature request rather than a bug-fix.
Sorry, I do not have a workaround for it.
Balaji
odurier
Message 5 of 5 (130 Views)
08-28-2013 12:10 AM in reply to: mbair
Thank you for your reply.
But you have more information about the availability of this feature.
This is a standard AutoCAD and our major clients use regularly.
But not able to print the entire layout seems to be a bug anyway.
