I have a c# launcher for my accoreconsole.Exe. I launch it through the command Process.Start
I launch accoreconsole.exe with a script scr to netload a class in c# (same framework 4.0)
If I launch the scr from a batch file (trhough cmd.exe, without my c# launcher), the scr is perfect. Runs without error
If I launch the scr from my soft in c# (trhough start process), the netload is succees, but I can't launch the command. Accoreconsole doesn't regonize my command.
I launch through :
netload d:\test.dll
I try with (command ..) Same issue.
Have you got any suggestions?
Acad : 2013, French and English version. Windows 8.0
Solved by nice-paca. Go to Solution.
Can you please try setting SECURELOAD to 0 in the script, before netload ?
If that does not help, please share a non-confidential sample project to reproduce the issue.
Balaji
I use Autocad2013, so I can't use Secureload.
To detail more my issue,
I launch Accoreconsole.exe trhough :
foreach (string filename in filenames)
Process acc = new Process();
const string quote = "\"";
optionsaccoreconsole = quote + pathsprog + "\\" + script;
options = "/i " + filename + " /s d:\\plot.scr";
acc.StartInfo.Arguments = options;
acc.StartInfo.FileName = acccoreconsole;
acc.Start();
with string pathsprog = Directory.GetCurrentDirectory();
quote = "\"";
My plot.scr is :
FILEDIA
0
NETLOAD d:\Plot.dll
plotpdf
FILEDIA
1
Thanks for your help
Fred
Hi Fred,
Not sure what is missing, but the DevTV sample launches a process similar to the one that you are trying.
http://adndevblog.typepad.com/autocad/2012/04/gett
I gave it a try and it worked ok using AccoreConsole which is part of 2013.
Does any other command get recognised ?
A simple SayHello command like this ?
[CommandMethod("MyCommands", "SayHello", CommandFlags.Modal)] public void SayHelloMethod() { DocumentCollection docs = Autodesk.AutoCAD.ApplicationServices.Core.Application.DocumentManager; Document activeDoc = docs.MdiActiveDocument; Editor ed = activeDoc.Editor; ed.WriteMessage(string.Format("{0}Hello !!", Environment.NewLine)); }
and a script which calls it
;Loading the .Net module (command "_.Netload" "D:\\Temp\\CustomPlugin.dll") ; Run the command (command "SayHello")
Balaji
The solution was simple.
In debug mode, I can't load a dll in accoreconsole.Exe
I need to launch a release version to have the possibility to load one.
