Hello all,
Context :
When AutoCAD Map 3D has started, I manually netload the DLL I create.
During my module initialisation, a DWT file is downloaded into the temp directory. A new document based on this DWT is created. This document contains many layers pointing to an oracle datasource through FDO. When this new document is created, by the code, I close all other document windows.
Once all is loaded, I manually (not programmatically) want to open a new additional Shape Connection. I select SHP Connection type in the Display Manager of the Task Pane, then I select a single file or a directory to connect to. I push the connect button, then, after checking checkboxes, I click on Add to map button.
At this time, 2 out of 3 around, I'm facing an AutoCAD Map crash.
In Debug context with VS12, the raised exception is AccessViolationException. There is no stacktrace in VisualStudio. There is either no details. The Exception is raised between the "CommandWillStart" and "CommandEnded" events handled on the document. The GlobalCommandName is "DMUI_ADDLAYERSUICMD". The message is "Tentative de lecture ou d'écriture de mémoire protégée. Cela indique souvent qu'une autre mémoire est endommagée."
When running Map out of VS12, I get the Fatal Error dialog box, and the Bug Report Window. Here are the Report Details :
<?xml version="1.0" encoding="UTF-8"?> <CERInfo ClientVersion="4"> <ProcessInfo AvailPhysicalMem="8BACE000" AvailPageFile="277024000" AvailVirtualMem="7FF87263000" LastWin32Error="1400" ErrNo="34" /> <UserInfo UserCanBeContacted="no" SerialNum=""> <UserName value =""/> <UserPhone value=""/> <UserEmail value=""/> <UserSubscription macID="" userId=""/> <ErrorDescription id="20" CrashDate="09/04/2014" CrashID="" AllowRT="1"></ErrorDescription> <Metrics CalendarUptime="3443099456253" RequiredSend="0" WaitDur="10000" /> <WorkingDocument name="Dessin2.dwg"/> </UserInfo> <upipackage><upivalue version="1.0" type="product" requestingapp="true"><level name="productline" id="MAP"><level name="release" id="2013"><level name="master" id="{5783F2D7-B002-040C-2102-0060B0CE6BBA}"><level name="build" id="16.0.210.5"/></level></level></level></upivalue> <upivalue version="1.0" type="product"><level name="productline" id="ADSKContentExplorer"><level name="release" id="2013"><level name="master" id="2013"><level name="build" id="3.0.0"/></level></level></level></upivalue> <upivalue version="1.0" type="product"><level name="productline" id="ADSKContentExplorer"><level name="release" id="2013"><level name="master" id="2013"><level name="build" id="3.0.0"/></level></level></level></upivalue> <upivalue version="1.0" type="product"><level name="productline" id="MAP"><level name="release" id="2014"><level name="master" id="{5783F2D7-D002-040C-2102-0060B0CE6BBA}"><level name="build" id="16.1.100.47"/></level></level></level></upivalue> </upipackage><OSInfo MajorVersion = "6" MinorVersion = "1" BuildNumber = "7601" PlatformId = "2" CSDVersion = "Service Pack 1" ServicePackMajor = "1" ServicePackMinor = "0" SuiteFlags = "100" KernelMajorVersion = "6" KernelMinorVersion = "1" KernelBuildNum = "7601" KernelReleaseNum = "18015"/> <LocaleInfo> <LocalUserDefault IDefaultAnsiCodepage="1252" IDefaultCodepage="850" IDefaultLanguage="140c" IDefaultCountry="352" ILanguage="140c" ICountry="352" /> <LocalSystemDefault IDefaultAnsiCodepage="1252" IDefaultCodepage="850" IDefaultLanguage="140c" IDefaultCountry="352" ILanguage="140c" ICountry="352" /> </LocaleInfo> <ProductInformation name ="AutoCAD" build_version="G.204.0.0(x64)" registry_version="19.0" install_id_string="ACAD-B002:40C" registry_localeID="1036" uptime="138713125181" session_start_count="253" session_clean_close_count="105" current_session_length="180"/><AdLmInformation init="0" command="0" conditions="" /><AppCDATA><![CDATA[Command: DMUI_ADDLAYERSUICMD;Groupe de commandes;D�but de groupe de commandes;Groupe de commandes;Groupe de commandes;Mapconnect UnloadedApps:aclaunchnfwws.arx(7fefa1e0000,13000); Clr Data: � AcMapDMUtilities.InsertGisElementFromFeatureSourceAndClasses(AcDbDatabase* , Char* , AcArray<wchar_t const \*\,AcArrayMemCopyReallocator<wchar_t const \*> >* , AcArray<wchar_t const \*\,AcArrayMemCopyReallocator<wchar_t const \*> >* , AcArray<wchar_t const \*\,AcArrayMemCopyReallocator<wchar_t const \*> >* , AcArray<wchar_t const \*\,AcArrayMemCopyReallocator<wchar_t const \*> >* , AcArray<int\,AcArrayMemCopyReallocator<int> >* , Boolean , Boolean , Boolean , Boolean ) � AcMapDMUtilities.InsertGisElementFromFeatureSourceAndClasses(AcDbDatabase* , Char* , AcArray<wchar_t const \*\,AcArrayMemCopyReallocator<wchar_t const \*> >* , AcArray<wchar_t const \*\,AcArrayMemCopyReallocator<wchar_t const \*> >* , AcArray<wchar_t const \*\,AcArrayMemCopyReallocator<wchar_t const \*> >* , AcArray<wchar_t const \*\,AcArrayMemCopyReallocator<wchar_t const \*> >* , AcArray<int\,AcArrayMemCopyReallocator<int> >* , Boolean , Boolean , Boolean , Boolean ) � AddLayersUICmd.Execute(AddLayersUICmd* ) ]]></AppCDATA> <GraphicsDriverInfo Driver = "acaddm11.hdi" /> <GraphicsInfo InfoType="D3D9Config"><![CDATA[ Driver: aticfx64.dll DriverVersion: 8.17.10.1151 Description: AMD FirePro M5950 DeviceName: \\.\DISPLAY2 VendorId: 4098 DeviceId: 26432 SubSysId: 372248636 Revision: 0 WHQLLevel: 0 DeviceType: 1 AdapterOrdinal: 0 Caps: 131072 Caps2: 3758227456 Caps3: 928 Presentation: 2147483663 Cursor: 1 Dev: 1818352 PrimitiveMisc: 4181234 Raster: 259219857 ZCmp: 255 SrcBlend: 16383 DestBlend: 16383 AlphaCmp: 255 Shade: 541192 Texture: 126021 TextureFilter: 117638912 CubeTextureFilter: 50529024 VolumeTextureFilter: 117638912 TextureAddress: 63 VolumeTextureAddress: 63 Line: 31 MaxTextureWidth: 16384 MaxTextureHeight: 16384 MaxVolumeExtent: 16384 MaxTextureRepeat: 8192 MaxTextureAspectRatio: 8192 MaxAnisotropy: 16 MaxVertexW: 1e+010 GuardBandLeft: -32768 GuardBandTop: -32768 GuardBandRight: 32768 GuardBandBottom: 32768 ExtentsAdjust: 0 Stencil: 511 FVF: 1048584 TextureOp: 67108863 MaxTextureBlendStages: 8 MaxSimultaneousTextures: 8 VertexProcessing: 379 MaxActiveLights: 8 MaxUserClipPlanes: 6 MaxVertexBlendMatrices: 4 MaxVertexBlendMatrixIndex: 0 MaxPointSize: 256 MaxPrimitiveCount: 5592405 MaxVertexIndex: 16777215 MaxStreams: 16 MaxStreamStride: 508 VertexShaderVersion: 4294836992 MaxVertexShaderConst: 256 PixelShaderVersion: 4294902528 PixelShader1xMaxValue: 3.40282e+038 Dev2: 113 MasterAdapterOrdinal: 0 AdapterOrdinalInGroup: 0 NumberOfAdaptersInGroup: 2 DeclTypes: 1023 NumSimultaneousRTs: 4 StretchRectFilter: 50332416 VertexTextureFilter: 50332416 MaxVShaderInstructionsExecuted: 4294967295 MaxPShaderInstructionsExecuted: 4294967295 MaxVertexShader30InstructionSlots: 32768 MaxPixelShader30InstructionSlots: 32768 ]]></GraphicsInfo> <DxDiagInfo><SystemInformation><OperatingSystem><![CDATA[64-bit Windows 7 Professional 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130828-1532)]]></OperatingSystem><Language><![CDATA[French (Regional Setting: French)]]></Language><SystemManufacturer><![CDATA[Hewlett-Packard]]></SystemManufacturer><SystemModel><![CDATA[HP EliteBook 8760w]]></SystemModel><BIOS><![CDATA[Default System BIOS]]></BIOS><Processor><![CDATA[Intel(R) Core(TM) i7-2620M CPU @ 2.70GHz (4 CPUs), ~2.7GHz]]></Processor><SystemMemory><![CDATA[8192MB RAM]]></SystemMemory><PageFile><![CDATA[5642MB used, 10640MB available]]></PageFile><FullDirectXVersion><![CDATA[DirectX 11]]></FullDirectXVersion><DxDiagVersion><![CDATA[6.01.7601.17514]]></DxDiagVersion></SystemInformation><GraphicsDeviceInfo><DirectXVersion><![CDATA[10.0]]></DirectXVersion><DDIVersion><![CDATA[11]]></DDIVersion><DDIVersionNumber><![CDATA[b]]></DDIVersionNumber><DxDiagWHQLLevel><![CDATA[0]]></DxDiagWHQLLevel><DriverSignedValid><![CDATA[True]]></DriverSignedValid><DriverSigned><![CDATA[True]]></DriverSigned><Manufacturer><![CDATA[Advanced Micro Devices, Inc.]]></Manufacturer><ChipType><![CDATA[ATI display adapter (0x6740)]]></ChipType><DACType><![CDATA[Internal DAC(400MHz)]]></DACType><GraphicsHWMemory><![CDATA[727 MB]]></GraphicsHWMemory><DisplayMode><![CDATA[1680 x 1050 (32 bit) (60Hz)]]></DisplayMode><VendorID><![CDATA[0x1002]]></VendorID><DeviceID><![CDATA[0x6740]]></DeviceID><SubSystemID><![CDATA[0x1630103C]]></SubSystemID><RevisionID><![CDATA[0x0000]]></RevisionID><GraphicsDriverFile><![CDATA[aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll]]></GraphicsDriverFile><DriverFileVersion><![CDATA[8.17.0010.1151]]></DriverFileVersion><DriverDate><![CDATA[11/21/2012 01:06:46]]></DriverDate><WHQLLevel><![CDATA[1]]></WHQLLevel></GraphicsDeviceInfo></DxDiagInfo><VideoDriverInfo><ATIPackagingVersion><![CDATA[9.003.3-121120a-151003C]]></ATIPackagingVersion></VideoDriverInfo> <LicenseInfo><ProductKey><![CDATA[129E1]]></ProductKey><FeatureName><![CDATA[MAP_F_S]]></FeatureName><FeatureVersion><![CDATA[2012.0319]]></FeatureVersion><LicenseBehavior><![CDATA[1]]></LicenseBehavior><LicenseUsage><![CDATA[1]]></LicenseUsage><LicenseExpiration><![CDATA[1]]></LicenseExpiration></LicenseInfo> </CERInfo>
Shape files seem to be good because I have no problem when connecting to them when my module is not netloaded.
What am I doing wrong ? Where could the problem ? Does anyone could help me ?
Best Regards,
Thomas.
