.NET
Active Member
THoffeller
Message 1 of 4 (228 Views)
Accessing Project Navigator Details with .Net
228 Views, 3 Replies
09-30-2013 06:40 AM
I'm trying to access the details one can define inside of the project configuration to handle their own field definitions for annotations.
I'm able to get the headers (folders) in the project configuration, but not the subdetails with their values. Is there a way to do this within the api or do I have to read the xml / apj file directly ? ;-(
Project _proj = null;
SetupProject ();
foreach (ProjectKey item in _proj.Configuration.StringProperties)
    foreach (var subitem in item. ??)
Thanks a lot,
Tim
ADN Support Specialist
augusto.goncalves
Message 2 of 4 (179 Views)
Re: Accessing Project Navigator Details with .Net
10-03-2013 11:53 AM in reply to: THoffeller
I'm not sure which product is that... despite you posted on AutoCAD blog, seems like Plant3d... can you clarify?
Augusto Goncalves
Autodesk Developer Network
Active Member
THoffeller
Message 3 of 4 (134 Views)
10-17-2013 08:54 AM in reply to: augusto.goncalves
Hi, it is for AutoCAD Architecture and AutoCAD MEP Project Navigator.
Tim
Active Member
THoffeller
Message 4 of 4 (134 Views)
10-17-2013 09:00 AM in reply to: augusto.goncalves
Hello Augusto,
I've found a solution to access the Details in Project Setup for AutoCAD Architecture and AutoCAD MEP:
foreach (ProjectStringProperty item in _proj.Configuration.StringProperties)
foreach (StringPair strpair in item.StringPairs)
string res = String.Format("[PROJ_DETAIL_{0}_{1}]", item.Name.ToUpper(), strpair.Left.ToUpper());
res = res.Replace(" ", "_");
_parameterColl.Add(res, strpair.Right);
But in general this Project API is more or less try and error... Took me some time to figure out, that StringProperties hold the ProjectDetails Collection ;-) Maybe you can add a wish to the list to rename this Property?
And some examples for this API would be fine in ACA/samples,
Thanks a lot,
Tim
