.NET
Accessing fields via .net
6 REPLIES 6
perry59
527 Views, 6 Replies
Is there some way to get a Field object?
Specifically I'm hoping it has an update method that I can call.
I ask because I've taken the VB sheetsets code from the AU course cp215-2 (filling the gaps in the sheet manager)
and have put it into VB.net. After a little tweeking it works except for one thing...
at one point the code writes some fields out in order to read back the string after the SSM has updated
the field codes. This works ok in the COM code, but doesnt work in NET. I can write the fields out fine
but they dont automatically update like in the COM version, so reading them back in does no good.
I need to write out the fields and do update to them before reading back the value.
Any pointers?
6 REPLIES 6
perry59
in reply to: perry59
No can do?
perry59
Well, I see what the problem is. "Field" is not defined in Acad 2006 .net even though the objects exist.
I was able to get references to "Field" objects on machines with Acad 2007 and later.
Anyone aware of some kinda workaround for this?
perry59
So nobody messes with fields?
Look at this post
http://through-the-interface.typepad.com/through_the_interface/2007/07/accessing-the-a.html
"perry59" schrieb im Newsbeitrag news:6336247@discussion.autodesk.com...
perry59
Yes, I did see that. It was very helpful, but unfortunately does not work
on our 2006 (stoneage) machines.
perry59
Perhaps through ARX, or pInvoke or some other esoteric method?
”Boost
