.NET
Accessing AutoCAD FIELDS and editing via VB.NET
3 REPLIES 3
dennis
2375 Views, 3 Replies
I have attached a DOC file that shows exactly the Plant 3D interface and the reference to the FIELD that I am after.  If someone can point me in the right direction, I want to access a FIELD (specifically the AREA field in an AutoCAD PLANT 3D drawing), and then set that FIELD value.
3 REPLIES 3
AubelecBE
in reply to: dennis
        'insertion du bloc !!!
        Dim RefBloc As BlockReference = Nothing
        Dim BlocT As BlockTable
        Dim CollObject As New Collection
        tr = db.TransactionManager.StartTransaction
        Try
            Dim ang As Object
            Dim CoteA, CoteB As Double
            Dim pointUcs As New Point3d(0, 500, 0)
            Dim pointdepart = Point3d.Origin
            pointdepart = pointdepart.TransformBy(Ed.CurrentUserCoordinateSystem.Inverse)
            pointUcs = pointUcs.TransformBy(Ed.CurrentUserCoordinateSystem.Inverse)
            CoteA = pointUcs.X - pointdepart.X
            CoteB = pointUcs.Y - pointdepart.Y
            Try
                ang = Math.Atan(CoteA / CoteB)
            Catch ex As Exception
                ang = 0
            End Try
            'si Coté B négatif alors angle >180 et <0 --> rotation de 180 à faire
            If CoteB < 0 Then ang = ang - Math.PI
            'Le bloc est à l'unité cm par défaut
            Dim Unite As Double
            Dim obj As Object = acApp.GetSystemVariable("INSUNITS")
            Select Case System.Convert.ToInt16(obj)
                Case 4 : Unite = 10 'mm
                Case 5 : Unite = 1   'cm
                Case 6 : Unite = 0.01   'm
                Case Else : Unite = 1
            End Select
            BlocT = tr.GetObject(db.BlockTableId, OpenMode.ForRead)
            Dim Bloc As BlockTableRecord
            'sélection de la zone d'insertion (Objet/papier)
            '1 si objet / 0 si papier
            Dim OkEspaceObjet As Integer = acApp.GetSystemVariable("TILEMODE")
            '1 si espace papier / 2 si dans Fenetre
            Dim OkEspacePapier As Integer = acApp.GetSystemVariable("CVPORT")
            If OkEspacePapier = 1 Then
                'Espace Papier
                Bloc = tr.GetObject(BlocT.Item(BlockTableRecord.PaperSpace), OpenMode.ForWrite)
                Unite = 0.5 '(car bloc en cm et papier en mm)
            Else
                'Espace Objet ou Fenetre dans Papier
                Bloc = tr.GetObject(BlocT.Item(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
            RefBloc = New BlockReference(PointDebutTableau, DefBloc.ObjectId)
            RefBloc.Layer = "0"
            RefBloc.Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.ByLayer, 256)
            RefBloc.ScaleFactors = New Scale3d(Unite, Unite, Unite)
            RefBloc.Rotation = ang
            Bloc.AppendEntity(RefBloc)
            tr.AddNewlyCreatedDBObject(RefBloc, True)
            Dim txt As String = ""
            Dim objID As ObjectId
            Dim vpIdVal As Long
            'Dim fieldEval As FieldEvaluationStatusResult = FieldObj.EvaluationStatus
            'If fieldEval.Status <> FieldEvaluationStatus.Success Then
            '    Ed.WriteMessage(vbCrLf & "FieldEvaluationStatus {0} - Message: {1}", fieldEval.Status, fieldEval.ErrorMessage)
            '    Exit Sub
            'Else
            'gestion des attributs
            Dim Index As Integer
            Dim FieldObj As Field
            Dim btAttRec As BlockTableRecord
            btAttRec = tr.GetObject(DefBloc.ObjectId, OpenMode.ForRead)
            Dim idAtt As ObjectId
            For Each idAtt In btAttRec
                Dim ent As Entity
                ent = tr.GetObject(idAtt, OpenMode.ForRead)
                If TypeOf ent Is AttributeDefinition Then
                    Dim attDef As AttributeDefinition
                    attDef = CType(ent, AttributeDefinition)
                    Dim attRef As New AttributeReference
                    attRef.SetAttributeFromBlock(attDef, RefBloc.BlockTransform)
                    'détection de l'att.
                    If attRef.Tag.Contains("NomXref") = True Then
                        Index = CInt(attRef.Tag.Replace("NomXref", ""))
                        txt = DataGridViewT.Rows.Item(Index).Cells(Enum_DataG.Handle).Value
                        objID = db.GetObjectId(False, New Handle(Int64.Parse(txt, Globalization.NumberStyles.AllowHexSpecifier)), 0)
                        vpIdVal = Convert.ToInt64(objID.ToString.Substring(1, objID.ToString.Length - 2))
                        FieldObj = New Field()
                        FieldObj.EvaluationOption = FieldEvaluationOptions.Automatic
                        FieldObj.SetFieldCode(String.Format("%<\AcObjProp Object(%<\_ObjId {0}>%).Name \f ""%tc4"">%", vpIdVal))
                        attRef.SetField(FieldObj)
                        CollObject.Add(attRef)
                    ElseIf attRef.Tag.Contains("CheminXref") = True Then
                        Index = CInt(attRef.Tag.Replace("CheminXref", ""))
                        If RadioButtonNomFichierPath.Checked = True Then
                            'Nom + Fichier
                            FieldObj.SetFieldCode(String.Format("%<\AcObjProp Object(%<\_ObjId {0}>%,1).Path \f ""%tc4"">%", vpIdVal))
                        Else
                            'Nom Fichier uniquement
                            FieldObj.SetFieldCode(String.Format("%<\AcObjProp Object(%<\_ObjId {0}>%,1).Path \f ""%fn6"">%", vpIdVal))
                    RefBloc.AttributeCollection.AppendAttribute(attRef)
                    tr.AddNewlyCreatedDBObject(attRef, True)
            Next
            MsgBox("Erreur à l'insertion du bloc", MsgBoxStyle.Critical & vbOKOnly, "Erreur système dans ClassFichier.GestionBlocTableau")
        Finally
            tr.Commit()
            tr.Dispose()
        End Try
        '-->V2.0.0.1
        'Regen pour générer le remplissage des champs.
#If _AcadVer_ = 2010 Then
        GestionAUTOCAD.LigneCommandeImmediate("_regenall")
#Else
        acApp.DocumentManager.MdiActiveDocument.Editor.Regen()
#End If
        '<--V2.0.0.1
here a sample code for inserting a blocreference and set a attribut with à field.
te attribut show the name of a Xref inserted in the dwg.
Sorry i am french so my annotation is in my language.
You cant copy/past this code in your vb app. but you cade use the part of the use of field.
dennis
in reply to: AubelecBE
Thanks AubelecBE, I will take a look at this today and see what I can do.  At first glance, you have pointed to an attribute changed to a field, while I am after the field of the drawing itself, much like maybe going after the Sheet Set Manager field.  But nonetheless, maybe I can make the jump over.
philippe.leefsma
in reply to: dennis
Check out my post, it illustrates how to find all fields in a drawing:
http://adndevblog.typepad.com/autocad/2014/07/how-to-find-all-fields-in-a-drawing.html
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
”Boost
