.NET
mgorecki
Message 11 of 17 (699 Views)
Re: Accessing AcadDocument and AcadApplication via .NET assembly
02-05-2013 04:30 PM in reply to: Balaji_Ram
I've looked into that code, but I couldn't get it to convert to VB.net.  Do you have a VB version?
Moderator
Alexander.Rivilis
Message 12 of 17 (691 Views)
02-05-2013 10:27 PM in reply to: mgorecki
What about using online C# <-> VB.NET converter?
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
mgorecki
Message 13 of 17 (685 Views)
02-06-2013 07:17 AM in reply to: Alexander.Rivilis
I've tried 2 different c# to VB converters and they both give me the same message, but for differing lines:
"An error occured converting your code, probably due to a syntax error:-- line 12 col 3: EOF expected"
I removed the extra spaces and changed the 17.1 to 18.0, but I still get the same error.
using System;
using System.Runtime.InteropServices;
using Autodesk.AutoCAD.Interop;
//This C# code can be added to an “on-click” event handler for a button (for example) or another function
//that makes sense in the context of your application.
  // "AutoCAD.Application.17" uses 2007 or 2008,
  //  whichever was most recently run
  // "AutoCAD.Application.17.1" uses 2008, specifically
  const string progID = "AutoCAD.Application.18.0";
  AcadApplication acApp = null;
  try
    acApp = (AcadApplication)Marshal.GetActiveObject(progID);
  catch
    try
      Type acType = Type.GetTypeFromProgID(progID);
      acApp = (AcadApplication)Activator.CreateInstance(acType, true);
    catch
      MessageBox.Show("Cannot create object of type \"" + progID + "\"");
  if (acApp != null)
    // By the time this is reached AutoCAD is fully
    // functional and can be interacted with through code
    acApp.Visible = true;
    acApp.ActiveDocument.SendCommand("_MYCOMMAND ");
Moderator
Alexander.Rivilis
Message 14 of 17 (681 Views)
02-06-2013 07:47 AM in reply to: mgorecki
Imports System
Imports System.Runtime.InteropServices
Imports Autodesk.AutoCAD.Interop
Namespace Test
    Public Class Test
        Public Shared Sub StartAutoCAD()
            ' "AutoCAD.Application.17" uses 2007, 2008, 2009
            '  whichever was most recently run
            ' "AutoCAD.Application.17.1" uses 2008, specifically
            ' "AutoCAD.Application.18" uses 2010, 2011, 2012
            ' "AutoCAD.Application.18.1" uses 2011, specifically
            ' "AutoCAD.Application.19" uses 2013,...
            Const progID As String = "AutoCAD.Application.19"
            Dim acApp As AcadApplication = Nothing
            Try
                acApp = DirectCast(Marshal.GetActiveObject(progID), AcadApplication)
            Catch
                Try
                    Dim acType As Type = Type.GetTypeFromProgID(progID)
                    acApp = DirectCast(Activator.CreateInstance(acType, True), AcadApplication)
                Catch
                    MessageBox.Show("Cannot create object of type """ & progID & """")
                End Try
            End Try
            If acApp IsNot Nothing Then
                ' By the time this is reached AutoCAD is fully
                ' functional and can be interacted with through code
                acApp.Visible = True
            End If
        End Sub
    End Class
End Namespace
mgorecki
Message 15 of 17 (666 Views)
02-07-2013 07:31 AM in reply to: Alexander.Rivilis
Hi Alexander,
This gets long, but I'm hoping you can help me out with this.
The scenario:
We have a web app that launches one program (just like the one below).  I add code to let the web app know AutoCad is running.
The web app then sends an array to another function in the same program.  The array sent has a handful of keys and variables.  My function reads the keys and variables to determine a second program to launch in Autocad (there are three potential programs to launch, the variables will let the code know which one to launch).
Once it knows, how does it go about doing the "netload", entering the path and .dll name of the program to launch, and then sending the command to launch the program (keeping in mind the program to launch will need to receive data, like passing the values of the variables)?
Thank you so much for helping me this far.
Mark
mgorecki
Message 16 of 17 (658 Views)
02-07-2013 10:32 AM in reply to: Alexander.Rivilis
Hello Alexander,
I think I found something that could work:
acApp.ActiveDocument.SendCommand("(command " & Chr(34) & "NETLOAD" & Chr(34) & " " & _
 Chr(34) & "C:\myFiles\myProgram.dll" & Chr(34) & ") ")
If that would work, and I have a sub called "POD" that's expecting an array, can I use acApp.ActiveDocument.SendCommand("(command "POD(arrayName)")")
Moderator
Alexander.Rivilis
Message 17 of 17 (656 Views)
02-07-2013 10:36 AM in reply to: mgorecki
I think I began to understand what you want. But you can not pass array to command any way.
