.NET
.NET
Distinguished Contributor
0 Kudos
Post 1 of 17
Accessing AcadDocument and AcadApplication via .NET assembly
670 Views, 16 Replies
05-12-2009 03:27 PM
Wondering if someone could please tell me what is the equivalent code of my COM accessing code below in .NET assembly?
For many years the code below has given me the results I needed but now I was told that I have to use .NET AutoCAD assemblies
instead and rewrite the code shown below so that it would use all the rich features provided via AutoDesk.AutoCAD.ApplicationServices.
In a nutshell, my code below allows me to grab an existing instance of AutoCAD or create a new one if no instance of AutoCAD is open then grabs the active AutoCAD document for my use. Thank you so much for all the kind help you could give
Gratefully,
Matt
My code is shown below:
Public ThisDrawing as Autodesk.AutoCAD.InterOp.AcadDocument
Public Sub CreateOrGetAutoCADinstance
Dim acadApp as Autodesk.AutoCAD.InterOp.AcadApplication
On Error Resume Next
acadApp = GetObject(, "AutoCAD.Application")
If Err.Number Then
acadApp = CreateObject("AutoCAD.Application")
End If
acadApp.Visible = True
ThisDrawing = acadApp.ActiveDocument
End Sub
3 Kudos
Post 2 of 17
Re: Accessing AcadDocument and AcadApplication via .NET assembly
05-12-2009 04:22 PM in reply to: matt_1ca
You can not use the AutoCAD .NET API from outside of AutoCAD. Therefore if you have an application that connects to an existing or creates a new instance of AutoCAD you will only be able to use the COM API.
54 Kudos
Post 3 of 17
05-12-2009 04:41 PM in reply to: matt_1ca
if you are going to be writing in .NET with the managed API, then you never have to and would probably never want to create an instance of AutoCAD. Your code will need to be compiled into a .dll instead of an .exe and your .dll will be loaded into autocad, instead of starting AutoCAD externally.
Application level methods and properties are then always accessible through ApplicationServices.Application.
Documents can be accessed via: dim acdocs as ApplicationServices.DocumentCollection = ApplicationServices.Application.DocumentManager, dim ThisDrawing as Document = acdocs.MdiActiveDocument
You can not use the managed API's from an external application.
0 Kudos
Post 4 of 17
05-13-2009 12:45 AM in reply to: matt_1ca
Thank you so much for this enlightening answer ... now, I have more control of the tools I use knowing that both COM and
.NET managed API have their places.
Gratefully,
Matt
0 Kudos
Post 5 of 17
05-13-2009 12:48 AM in reply to: matt_1ca
Thank you so much for this valuable answer... this gives me the nuts and bolts I need to
build my .NET managed API solution ... now I can proceed with more confidence
towards this new frontier.
Gratefully,
Matt
0 Kudos
Post 6 of 17
01-30-2013 12:46 PM in reply to: chiefbraincloud
Hello, I'm having a similar problem.  We have a web appliaction that will create a 2D array, then launch my .dll and pass it the array.  My code is supposed to launch AutoCad and then create a drawing using the info passed in the array.
I also want to check to see if AutoCad is running already.
Thanks in advance for your help
Mark
37 Kudos
Post 7 of 17
01-30-2013 01:13 PM in reply to: matt_1ca
    Public Function isAutocadOpen() As Boolean
        Dim rtnValue As Boolean
        Dim ProcessList As System.Diagnostics.Process()
        Dim Proc As System.Diagnostics.Process
        ProcessList = System.Diagnostics.Process.GetProcesses()
        Try
            For Each Proc In ProcessList
                If UCase(CStr(Proc.ProcessName)) = UCase("acad") Then
                    MsgBox(Proc.Id.ToString)
                    rtnValue = True
                End If
            Next
        Catch ex As Exception
        End Try
        Return rtnValue
    End Function
(defun botsbuildbots() (botsbuildbots))
0 Kudos
Post 8 of 17
01-30-2013 01:26 PM in reply to: arcticad
Hi, thank you very much for that code.  I'll try it out.
Best regards,
Mark
0 Kudos
Post 9 of 17
01-31-2013 08:29 AM in reply to: arcticad
Again, thanks for the code.  I was also wondering if you could give me the command that will launch AutoCad if it's not currently running.  I don't normally ask for stuff like this, but I've looked all over and found many convoluted websites or sites that I needed to have a phd in programming to understand.
ADN Support Specialist
100 Kudos
Post 10 of 17
02-01-2013 09:14 AM in reply to: mgorecki
Please look for the usage of "Activator.CreateInstance" as in this blog post :
http://through-the-interface.typepad.com/through_the_interface/2007/12/launching-autoc.html
In the sample code from the blog post, remember to change the progId based on the version of AutoCAD that you want to launch. For example : "AutoCAD.Application.19" for AutoCAD 2013.
Balaji
Developer Technical Services
Autodesk Developer Network
