.NET
Access BlockPropertiesTable from a BlockReference
6 REPLIES 6
JF_005
767 Views, 6 Replies
I use a block entity that contains a BlockPropertiesTable (not a LookupTable) with dimension constraints and user parameters. I managed to find sample code on how to get the current value of these parameters (
AssocNetwork class), but I don't know how to access the ObjectId of the BlockPropertiesTable from my BlockReference. This would be useful to get a list of all values available for a specific parameter in the table for example.
Any help would be much appreciated.
6 REPLIES 6
philippe.leefsma
in reply to: JF_005
Hi JF,
Can you please provide a minimal sample file containing your block, so I can take a closer look.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
JF_005
in reply to: philippe.leefsma
Here you go. This is a pipe fitting tee. The primary column of the BlockPropertiesTable lets you chose the fitting nominal pipe size (3/4"-NPT for example).
I know I can change the BlockReference property value (current row to display) like this:
For Each prop As DynamicBlockReferenceProperty In br.DynamicBlockReferencePropertyCollection
    If prop.PropertyName.ToUpper() = "BLOCK TABLE1" Then
        prop.Value = CShort(2)
    End If
Next
 But this does not give me any info about the the rows and columns of the BlockPropertiesTable entity.
Thanks in advance for your help! Smiley Happy
philippe.leefsma
in reply to: JF_005
The API for dynamic block is not very powerful, accessing parameters is basically all you can do, so the information you are looking for is probably not accessible directly.
You may want to check the following post, it exposes an approach to discover additional properties, but it involves some personal research on your side:
http://adndevblog.typepad.com/autocad/2012/05/accessing-visible-entities-in-a-dynamic-block.html?cid...
I hope it helps,
Philippe.
Philippe Leefsma
JF_005
By the way, I code in VB but I don't mind if the solution is in VB or C#. (I'm used to convert from C# to VB)
JF_005
Thank you, i'll check this out.
DiningPhilosopher
in reply to: JF_005
And, in case the graphics that were not lifted from the original article might help, here's a link:
http://forums.autodesk.com/t5/NET/Dynamic-block-question/m-p/2640949#M18132
”Boost
