.NET
699 Views, 1 Reply
AcadTable
What reference do I need to get at AutoCAD Tables. In VBA I would do:
Dim MyTable as AcadTable
In VB.NET I tried:
Dim MyTable as Autodesk.AutoCAD.Interop.?????
Thanks in advance for the help
1 REPLY 1
If you are searching through Object Browser in VS and you don't find AcadTable, you need to reference the "AutoCAD/ObjectDBX Common 16.0" COM DLL. Once referenced, you'll find AcadTable in Autodesk.AutoCAD.Interop.Common.
”Boost
