Here is the full class.
MFZ
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Imports System.Runtime.InteropServices
Imports System.Runtime.InteropServices.Marshal
Imports System.Threading
Imports System.IO
Public Class AcadApp
Implements IAppController 'Interface to control application in a standard way
Implements IDisposable
#Region "Variables"
Private _App As AcadApplication
Private _Document As Autodesk.AutoCAD.Interop.AcadDocument
Private _FullPath As String = String.Empty
Private _AppStarted As Boolean = False
Private _AcadVersion As String = "AutoCAD.Application.17"
Private _Visable As Boolean = False
'Private _PaperSize As String = "ANSI D (34.00 x 22.00 Inches)"
'Private _AcadPaperSize As String = "ANSI_D_(34.00_x_22.00_Inches)"
'Private _PC3Printer As String = "DWG To PDF.pc3"
Private _PrintSettings As New AcadPrintSettings ' Setup with default settings
Private _PrintersAvailable As ArrayList
Private _SourcePath As String = String.Empty
Private _DestinationPath As String = String.Empty
Private disposedValue As Boolean = False ' To detect redundant calls
#End Region
#Region "Interface Properties"
Public ReadOnly Property App() As Object Implements IAppController.App
Get
Return _App
End Get
End Property
Public Property Document() As Object Implements IAppController.Document
Get
Return _Document
End Get
Set(ByVal value As Object)
_Document = TryCast(value, AcadDocument)
End Set
End Property
Public Property FullPath() As String Implements IAppController.FullPath
Get
Return _FullPath
End Get
Set(ByVal value As String)
_FullPath = value
End Set
End Property
Public ReadOnly Property AppStarted() As Boolean Implements IAppController.AppStarted
Get
Return _AppStarted
End Get
End Property
Public Property Visable() As Boolean Implements IAppController.Visable
Get
Return _Visable
End Get
Set(ByVal value As Boolean)
_Visable = value
_App.Visible = value
End Set
End Property
Public Property DestinationPath() As String Implements IAppController.DestinationPath
Get
Return _DestinationPath
End Get
_DestinationPath = value
End Set
End Property
Public Property SourcePath() As String Implements IAppController.SourcePath
Get
Return _SourcePath
End Get
_SourcePath = value
End Set
End Property
#End Region
#Region "Properties"
Public Property AcadVersion() As String
Get
Return _AcadVersion
End Get
_AcadVersion = value
End Set
End Property
Public Property PrintSettings() As AcadPrintSettings
Get
Return _PrintSettings
End Get
Set(ByVal value As AcadPrintSettings)
_PrintSettings = value
End Set
End Property
#End Region
#Region "Private Functions"
Private Function VerifyPrinter() As Boolean
Dim bSuccess As Boolean = False
Dim iCount As Integer
Try
For iCount = 0 To _PrintersAvailable.Count
If _PrintersAvailable.Item(iCount).ToString = _PrintSettings.PC3Printer Then
bSuccess = True
Exit For
Next
Catch ex As ApplicationException
'ex.Source = "AcadApp.VerifyPrinter"
HandledExceptionManager.ShowDialog("Error Verifying Printer to use in function AcadApp.VerifyPrinter", _
"Printing will not take place", _
"Change Printer to be used, to one that is available", _
ex, , , , True)
Throw ex
End Try
Return bSuccess
End Function
Private Function GetPC3Files() As ArrayList
Dim htFiles As New ArrayList
Dim fileName As String = vbNullString
Dim pc3Name As String = vbNullString
Dim fileEntries As String()
'Dim iCount As Integer
Try
fileEntries = Directory.GetFiles(_App.Preferences.Files.PrinterConfigPath.ToString())
'Process the list of files found in the directory
'For iCount = LBound(fileEntries) To UBound(fileEntries)
' fileName = fileEntries(iCount)
For Each fileName In fileEntries
If Path.GetExtension(fileName).Equals(".pc3") Then
pc3Name = Path.GetFileName(fileName).ToString
htFiles.Add(pc3Name)
Next
Catch ex As Exception
HandledExceptionManager.ShowDialog("Error Building List of PC3 files in function AcadApp.GetPC3Files", _
"Verify Autocad and PC3 files are installed", _
ex, , , , True)
End Try
Return htFiles
End Function
Private Function VerifyPaper(ByVal strPaperSize) As Boolean
Dim Layout As AcadLayout
Dim iIndex As Integer
Dim bVerifyPaper As Boolean = False
Dim MediaNames As Object
Try
'Set the layout
Layout = _Document.ActiveLayout
With Layout
'Set the printer
.ConfigName = _PrintSettings.PC3Printer
.RefreshPlotDeviceInfo()
'Get list of paper
MediaNames = .GetCanonicalMediaNames
'Test printer matches PaperSize property
For iIndex = LBound(MediaNames) To UBound(MediaNames)
''NOTE **********************************************************
''.GetLocalMediaName returns man readable value similar to
''paper values in plot dialog but not the value needed to be set
''mediaNames(index) returns the name needed for the plot
'Debug.Print(.GetLocaleMediaName(MediaNames(iIndex)))
If .GetLocaleMediaName(MediaNames(iIndex)) = strPaperSize Then
_PrintSettings.AcadPaperSize = MediaNames(iIndex)
_PrintSettings.PaperSize = strPaperSize
bVerifyPaper = True
Exit For
Next
End With 'Layout
'Dim ex As New ApplicationException
'ex.Source = "AcadApp.VerifyPaper"
HandledExceptionManager.ShowDialog("Error Verifying Paper Size to use in function AcadApp.VerifyPaper", _
"Change Paper size to be used, to one that is available", _
ex, , , , True)
Throw ex
End Try
Return bVerifyPaper
End Function
#End Region
#Region "Interface Functions"
Public Sub New()
Try
'get existing 2007
_App = GetActiveObject(_AcadVersion)
_AppStarted = True
Catch
Try
'create 2007
_App = CreateObject(_AcadVersion)
'set started flag
_AppStarted = True
_AppStarted = False
Throw ex
End Try
End Try
_PrintersAvailable = GetPC3Files()
End Sub
'''TODO Add Overloaded new with parameters
Public Function Quit() As Boolean Implements IAppController.Quit
Try
_App.Quit()
_AppStarted = False
Marshal.ReleaseComObject(_Document)
Marshal.ReleaseComObject(_App)
bSuccess = True
Throw ex
End Try
Return bSuccess
End Function
Public Function Open() As Boolean Implements IAppController.Open
Try
'_Document = New Autodesk.AutoCAD.Interop.AcadDocument
_Document = _App.Documents.Open(_SourcePath, False)
'_App.Visible = _Visable
'Check for ModelSpace and Zoom Extents
If _Document.ActiveLayout.Name.ToUpper <> "MODEL" Then
If _Document.ActiveSpace = AcActiveSpace.acPaperSpace Then
_App.ZoomExtents()
Else
_App.ZoomExtents()
bSuccess = True
Throw ex
End Try
Return bSuccess
End Function
Public Function Close() As Boolean Implements IAppController.Close
Try
_Document.Close(False)
'Marshal.ReleaseComObject(_Document)
bSuccess = True
Throw ex
End Try
Return bSuccess
End Function
Public Function Print() As Boolean Implements IAppController.Print
Try
'Set Space to the first Paper space Layout
With _Document
Trace.WriteLine("Before Set space to AcPaper")
.MSpace = False
End With '_Document
Trace.WriteLine("After Set space to AcPaper")
'Get plot setting and print to pdf
With _Document.ActiveLayout
'Get the origin before changing printers
_PrintSettings.PrintOrigin = .PlotOrigin
'Before begining Verify Printer settings
If VerifyPrinter() Then
'set config name here
Else
'ex.Source = "AcadApp.Print Printer " & _PrintSettings.PC3Printer & " is not valid"
'Add new exception handler
ex, , , , True)
Throw ex
'Need to set config name first to test paper
If VerifyPaper(_PrintSettings.PaperSize) Then
.CanonicalMediaName = _PrintSettings.AcadPaperSize
Else
'ex.Source = "AcadApp.Print Paper size " & _PrintSettings.AcadPaperSize & " is not valid"
HandledExceptionManager.ShowDialog("Error Verifying Papersize to use in function AcadApp.Print ", _
ex, , , , True)
Throw ex
'''TODO Test for Mspace dimensions and set for landscape or portrait
'''TODO Set CTB Style sheet
'''TODO .StyleSheet = ??
'''TODO .PlotwithStyles = true
'plotting origin from original
.PlotOrigin = _PrintSettings.PrintOrigin
'Plot type as layout
.PlotType = _PrintSettings.PrintType
'set plot scale
.StandardScale = _PrintSettings.PrintScale
'Refresh the plotting device
Trace.WriteLine("Before Refresh plot device Setplot origins scale")
End With 'ActiveLayout
'regen layout
If _Visable Then
_App.ZoomExtents()
_Document.Regen(AcRegenType.acAllViewports)
Else
'Create the Destination Directory
Directory.CreateDirectory(Path.GetDirectoryName(_DestinationPath))
'Check to make sure Acad is ready
'Loop for Timing
'While Not _App.GetAcadState.IsQuiescent
' System.Threading.Thread.Sleep(500)
'End While
_Document.ActiveLayout.RefreshPlotDeviceInfo()
'Do the plot
With _Document.Plot
.QuietErrorMode = True
.NumberOfCopies = 1
'Test for file Exist
Trace.WriteLine("Before plot toFile")
'Loop for Timing
End While
bSuccess = .PlotToFile(_DestinationPath)
Trace.WriteLine("After plot toFile")
End With
'Pause to let Acad finish plotting
'Thread.Sleep(5000)
'if error then log error
HandledExceptionManager.ShowDialog( _
"Error Ploting to file with file " & _SourcePath, _
"This file will be skipped", _
"Check plotting settings on this file", _
ex, , , , True)
End Try
Return bSuccess
End Function
#End Region
#Region " IDisposable Support "
' IDisposable
Protected Overridable Sub Dispose(ByVal disposing As Boolean)
If Not Me.disposedValue Then
If disposing Then
' TODO: free unmanaged resources when explicitly called
Try
If Not _App Is Nothing Then
Me.Quit()
Catch
End Try
' TODO: free shared unmanaged resources
Me.disposedValue = True
End Sub
' This code added by Visual Basic to correctly implement the disposable pattern.
Public Sub Dispose() Implements IDisposable.Dispose
' Do not change this code. Put cleanup code in Dispose(ByVal disposing As Boolean) above.
Dispose(True)
GC.SuppressFinalize(Me)
End Sub
#End Region
End Class
