.NET
acadDB.SaveAs() AccessViolationException
2 REPLIES 2
442 Views, 2 Replies
While processing the drawing files in batch mode, the below given statement raise 'AccessViolationException' [Attempted to read or write protected memory. This is often an indication that other memory is corrupt.]. But the same statement works for spare Drawing files. How to fix this issue?
acadDB.SaveAs(outputPath & "\" & dwgName.ToString & ".dwg", True, DwgVersion.Current, Nothing)
Tags (2)
2 REPLIES 2
Littlerubarb
Please elaborate, the code looks correct but does it work on some files or none?
I assume you read/write drawing using ReadDwgFile.
Before saveas command check open drawing file already close and released in memory.
I have the same issue and I sove this using below code.
Hope this will help.
If this code not help, please explain your issue little more.
code:
  string tempFileName = System.IO.Path.GetTempFileName();
  acadDB.CloseInput(true);
  // save as temp file
  acadDB.SaveAs(tempFileName, DwgVersion.Current);
   // dispose the database
  // now replace
  System.IO.File.Copy(tempFileName, File_name_path, true);
  // and erase the temp file
  System.IO.File.Delete(tempFileName);
thenndral
”Boost
