.NET
Valued Contributor
Ertqwa
Message 1 of 10 (863 Views)
AcadApplication - InvokeMember
863 Views, 9 Replies
11-11-2012 12:23 AM
Hello Forum,
I want to find out which members I can invoke on the class Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication, like this:
[CommandMethod("zoomExtentTest")]
public static void zoomExtentTest()
   Object acadObject = Application.AcadApplication;
acadObject.GetType().InvokeMember("ZoomExtents",
   BindingFlags.InvokeMethod, null, acadObject, null);
 However, AcadApplication returns type Object so I'm getting nowhere with "System.Reflection".
Any one knows how to list all members that I can invoke, or if there is an overview somewhere?
Thank you.
What about using the COM/ActiveX documentation available here:
http://usa.autodesk.com/adsk/servlet/index?id=1911627&siteID=123112
khoa.ho
Message 2 of 10 (832 Views)
Re: AcadApplication - InvokeMember
11-12-2012 08:58 AM in reply to: Ertqwa
Using Reflection of AutoCAD COM Interop, we will get all methods to invoke. The following code will get all methods of a loaded AutoCAD application:
public static Dictionary<string, string> GetAcadInteropMethods(object acadApp)
    if (acadApp == null)
        return null;
    var methodDict = new Dictionary<string, string>();
    MethodInfo[] methods = acadApp.GetType().GetMethods();
    foreach (MethodInfo methodInfo in methods)
        string methodName = methodInfo.Name;
        string methodReturnType = methodInfo.ReturnType.Name;
        methodDict.Add(methodName, methodReturnType);
    return methodDict;
-Khoa
Valued Contributor
Ertqwa
Message 3 of 10 (803 Views)
11-13-2012 10:26 AM in reply to: khoa.ho
Hi, ty for your response.
Your code returns the following:
GetLifetimeService, Object
InitializeLifetimeService, Object
CreateObjRef, ObjRef
ToString, String
Equals, Boolean
GetHashCode, Int32
GetType, Type
It does not, for example, returns "ZoomExtents", but I can invoke it. I want to find all membersI can invoke.
Hallex
Message 4 of 10 (796 Views)
11-13-2012 11:15 AM in reply to: Ertqwa
Sorry you could try it on existing instance of application,
then it will work like a sharm
Something like this:
   public static class AcadInteropApp
       public  static Autodesk.AutoCAD.Interop.AcadApplication AcadApp =
            (Autodesk.AutoCAD.Interop.AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
        private static AcadDocument acdoc()
            if (AcadApp != null)
                return AcadApp.ActiveDocument;
            else
                return null;
        [CommandMethod("mets")]
        public static void doit()
            Autodesk.AutoCAD.Interop.AcadDocument doc = AcadInteropApp.AcadApp.ActiveDocument;
            Dictionary<string, string> dict = GetAcadInteropMethods(doc);
            AcadUtility acutil=doc.Utility;
            foreach (KeyValuePair<string,string> kvp in dict)
                acutil.Prompt("\nMethod name=" + kvp.Value.ToString());
           // AcadInteropApp.AcadApp.Quit();
                return null;
            return methodDict;
        } //   Khoa     //
khoa.ho
Message 5 of 10 (795 Views)
11-13-2012 11:54 AM in reply to: Hallex
Hallex is right to give the full code to run the given method. Thank you.
-Khoa
Valued Mentor
DiningPhilosopher
Message 6 of 10 (782 Views)
11-13-2012 07:42 PM in reply to: Ertqwa
The other replies you received all assume that you are using the COM interop assemblies, which is probably not the case, or you wouldn't need to invoke members via reflection.
If you are using late binding (e.g., not importing the COM interop assemblies) the only way to reflect on a COM object is to access its type library using ITypeInfo or ITypeInfo2 COM interfaces, which is fairly complicated.
A workaround would be to load the AutoCAD COM interop assemblies  into the reflection-only context (see  Assembly.ReflectionOnlyLoadFrom() in the docs), and then you can reflect on the the runtime-callable wrappers (e.g., AcadApplication, AcadDocument, etc.).
Valued Contributor
Ertqwa
Message 7 of 10 (748 Views)
11-18-2012 12:10 AM in reply to: Hallex
Hi, ty for you response.
When I use your method, I get a lot of results, but not all. For Example, "ZoomExtents" is not in the return values:
0: Void
1: Void
2: Void
3: Void
4: Void
5: Void
6: Void
7: Void
8: Void
9: Void
10: Void
11: Void
12: Void
13: Void
14: Void
15: Void
16: Void
17: Void
18: Void
19: Void
20: Void
21: Void
22: Void
23: Void
24: Void
25: Void
26: Void
27: Void
28: Void
29: Void
30: Void
31: Void
32: Void
33: Void
34: Void
35: Void
36: Void
37: Void
38: Void
39: Int64
40: String
41: IAcadApplication
42: AcadDatabase
43: Void
44: Void
45: AcadMaterial
46: Void
47: Int32
48: Void
49: Void
50: Void
51: Void
52: Void
53: Void
54: Void
55: Void
56: Void
57: Void
58: Void
59: Void
60: Void
61: Void
62: Void
63: Void
64: Void
65: Void
66: Boolean
67: Void
68: AcadUtility
69: AcadDocument
70: Void
71: Object
72: Void
73: AcadDocument
74: Void
75: Void
76: Void
77: Void
78: Object
79: Void
80: Void
81: Void
82: AcadSelectionSet
83: Boolean
84: Void
85: Void
86: Void
87: AcWindowState
88: Void
89: Int32
90: Void
91: Int32
92: Void
93: AcadLayout
94: AcadMaterials
95: Object
96: AcadPlot
97: AcadLayer
98: Void
99: AcadLineType
100: Void
101: AcadDimStyle
102: Void
103: AcadTextStyle
104: Void
105: AcadUCS
106: Void
107: AcadViewport
108: Void
109: AcadPViewport
110: Void
111: AcActiveSpace
112: Void
113: AcadSelectionSets
114: AcadSelectionSet
115: String
116: String
117: String
118: Boolean
119: Void
120: Boolean
121: Boolean
122: AcadModelSpace
123: AcadPaperSpace
124: AcadBlocks
125: Object
126: AcadGroups
127: AcadDimStyles
128: AcadLayers
129: AcadLineTypes
130: AcadDictionaries
131: AcadRegisteredApplications
132: AcadTextStyles
133: AcadUCSs
134: AcadViews
135: AcadViewports
136: Double
137: Void
138: Double
139: Void
140: Object
141: Void
142: Object
143: Object
144: AcadLayouts
145: AcadPlotConfigurations
146: AcadDatabasePreferences
147: AcadFileDependencies
148: AcadSummaryInfo
149: AcadSectionManager
150: Object
151: Object
152: ObjRef
153: String
154: Boolean
155: Int32
156: Type
Found: 157
Code:
            int i = 0;
            try
                Autodesk.AutoCAD.Interop.AcadDocument doc = AcadApp.ActiveDocument;
                Autodesk.AutoCAD.Interop.AcadUtility acutil = doc.Utility;
                    Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("\n{0}: {1}", i.ToString(), kvp.Value.ToString());
                    i++;
                Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("\nFound: {0}", dict.Count.ToString());
            catch (System.Exception Ex)
            { MessageBox.Show("Error testing GetAcadInteropMethods on CADS.Application.AcadApplication: " + Ex.ToString(), "Error", MessageBoxButtons.OK, MessageBoxIcon.Error); }
Thanks.
Valued Contributor
Ertqwa
Message 8 of 10 (746 Views)
11-18-2012 12:13 AM in reply to: DiningPhilosopher
Hi ty for your response.
Yes you are right, all of this is to avoid using the COM interop assemblies. However, as you state yourself, I do not mind using the COM interop assemblies to get the information I need, as long as it wont end up in the final application.
Using COM interop assemblies was working fine until the application had to run on both CAD2009 (32bit) and CAD2012 (64bit).
_gile
Message 9 of 10 (730 Views)
11-18-2012 05:54 AM in reply to: Ertqwa
Gilles Chanteau
Valued Contributor
Ertqwa
Message 10 of 10 (668 Views)
12-08-2012 12:05 AM in reply to: _gile
Great thanks, found a list in acadauto.chm.
