.NET
Acad2010 thumbnail
10 REPLIES 10
Message 1 of 11
1024 Views, 10 Replies
Acad2010 thumbnail
I have a programm in Autocad 2009 that change something in a series of Dwg
and when i make closeandsave(filename) store also the thumbnail.
I see the preview in explorer.
Now i have install Acad2010 and recompile the program with the new
library,but the closeandsave(filename) don't store the thumbnail.
Some help?
thanks in advance.
GPQ
10 REPLIES 10
Message 2 of 11
In AutoCAD 2010 or later, you can call the
Document's CreatePreviewImage() method,
and assign the result to the Database's
ThumbnailBitmap property.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2011
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
"GPaolo" wrote in message
news:6379160@discussion.autodesk.com...
Some help?
thanks in advance.
GPQ
Message 3 of 11
gpq
Yes,i have see it and i have already try it,but when i save in Acad i obtain a thumbnail with white background color (in explore) when i create thumbnail by program with the function "CreatePreviewImage" i obtain a thumbnail indefinite and with black background color like my background color in Acad.
Any other suggestion?
Thanks and good week-end.
GPQ
Message 4 of 11
The thumbnail stored in the database should be the
same as the one returned by CapturePreviewImage().
It's possible that the background color is manipulated
when Explorer requests the thumbnail.
wrote in message
news:6379790@discussion.autodesk.com...
GPQ
Message 5 of 11
If you're using AutoCAD 2011, then don't bother with this method.
Autodesk apparently has broken this method an if you call it
AutoCAD will stop responding.
wrote in message
GPQ
Message 6 of 11
No,i use Acad2010.
My Background color in Acad2010 is black like in Acad2009 and if i save the
drawing by Acad the thumbnail that i see is correct.
If i save the same drawing by .net program i don't obtain the same thing.
Thank's.
GPQ
"Tony Tanzillo" ha scritto nel messaggio
news:6379897@discussion.autodesk.com...
wrote in message
obtain a
by
indefinite
GPQ
Message 7 of 11
version Acad2009:
doc.LockDocument.Dispose()
doc.CloseAndSave(NomeDwg)
doc.Dispose()
I have replace it in Acad2010 version with :
'Dim bm As Bitmap = doc.CapturePreviewImage(128, 102) Not used
'doc.Database.ThumbnailBitmap() = bm
Not used
doc.Database.SaveAs(NomeDwg, True, AcDbs.DwgVersion.Current,
doc.Database.SecurityParameters)
doc.CloseAndDiscard()
doc.Dispose()
Now all work fine like in Acad2009 version.
Thank's Tony
wrote in message
obtain a
by
indefinite
GPQ
Message 8 of 11
Great, but don't expect it to work in 2011.
news:6380212@discussion.autodesk.com...
version Acad2009:
doc.Dispose()
Not used
doc.Dispose()
Thank's Tony
wrote in message
obtain a
by
indefinite
GPQ
Message 9 of 11
josano
I tried using the above code with c # but I could not use CreatePreviewImage () method.
Can anyone help me how do I get the thumbnail and display it in a picturebox in autocad 2008?
Josano Edited by: josano on Apr 26, 2010 1:27 PM
Message 10 of 11
There is ocx that make this job ,but i have found from other developer a
class that i have modify to change also the background color of thumbnail.
Try to use it.
Ciao
ha scritto nel messaggio news:6380348@discussion.autodesk.com...
Josano
Message 11 of 11
tim-bot
yes, the CapturePreviewImage in 2011 is definitly broken good, any ideas on a better way to grab the screen? i might just use the regular .net screen shot and clip the image myself that way, though, i would perfer the capturepreviewimage B(
”Boost
