.NET
About "FATAL ERROR:Unhandled Access Violation Writing 0x5fb5....
3 REPLIES 3
sdphg
719 Views, 3 Replies
Our application runs well. but yestoday, some guys change their computers, when they execute the command defined by our application, AutoCAD will collapse with FATAL ERROR.But the command build in AutoCAD such as "Line" doesn't.
Any suggestions? this is an emergency problem,so any reply will be appreciate.thank you all.
3 REPLIES 3
Alfred.NESWADBA
in reply to: sdphg
What did they change? Did they get new pc's or did they change person A to pc B and vice versa?
What happens if "they change back"?
When you load your application with _NETLOAD ==> do you/do they get any messages?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
in reply to: sdphg
Did the version of Autocad change? OS?
Cheers,
Martin.
sdphg
in reply to: sdphg
thank you guys. Problem is gone after install AutoCAD2007 SP1.
”Boost
