.NET
about database.insert()
3 REPLIES 3
697 Views, 3 Replies
Hi guys! Have anyone used this function?
Autodesk.AutoCAD.DatabaseServices.Database.Insert(Autodesk.AutoCAD.Geometry.Matrix3d, Autodesk.AutoCAD.DatabaseServices.Database, Boolean)
What's the Matrix3d  when I insert a database from other file?
Thank you!
3 REPLIES 3
artc2
Here's the docs
Inserts the Model Space of the database pointed to by dataBase into the Model Space of the database invoking the insert() function. All objects being inserted have the xform matrix passed into their transformBy() function during the insertion process.
The preserveSourceDatabase argument determines whether the source database dataBase is left intact or not. The default value of the argument is true. In that case, objects from the source database are copied to the destination database and the source database is not changed. If the caller passes false for this argument, objects from the source database could be physically moved into the destination database. The latter runs faster, but it leaves the source database dependent on the destination database. The caller should make sure that the source database is deleted either immediately or at least before the destination database is deleted.
in reply to: artc2
Can you give any simple example? Thank you for your reply!
artc2
Sorry, I don't have any sample code.  Perhaps someone else here does.
”Boost
