.NET
Valued Contributor
NKCAUTOCAD01
Message 1 of 3 (159 Views)
Accepted Solution
About an object event, I want you to tell me.
159 Views, 2 Replies
01-15-2013 11:14 PM
Using AutoCAD.NETAPI, I had same advise the method that handled object event
(Objec tAppended) in our discussion group
and came to be able to pick up an event when I carried out paste1 in the following logics.
Public Sub Paste1() 'object addition event
  Dim tdoc As Document = Application.DocumentManager.MdiActiveDocument Dim tdb As
  Database = tdoc.Database AddHandler tdb.ObjectAppended, AddressOf ObjectAdd
End Sub
 However, trigger of the double of the number of element that I stuck by
this event occurs when I stick the element which I took in _copybase in _pasteclip.
In addition, ObjectId, OwnerId of the element becomes inherent each, too and which is
a real element or, in each trigger, cannot distinguish it.I analyze only a stuck element
I want to handle it, would you advise a method to distinguish?
Thanking you in advance.
Command _PASTECLIP create temporary block definition with entities copied  _COPYBASE command. After specifying insertion point, block will be erased and entities added to current space (Model or Paper). You can check Entity.BlockId equal Database.CurrentSpaceId or no.
Moderator
Alexander.Rivilis
Message 2 of 3 (147 Views)
Re: About an object event, I want you to tell me.
01-16-2013 02:22 AM in reply to: NKCAUTOCAD01
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Contributor
NKCAUTOCAD01
Message 3 of 3 (127 Views)
01-16-2013 05:12 PM in reply to: Alexander.Rivilis
Dear Mr. Alexander.Rivilis
Thank you for the Great advice.
It was saved very much.Yours sincerely,
NKCAUTOCAD01 (M.Tsukamoto)...
Announcements
Need installation help?
