.NET
Member
detox
Message 1 of 2 (114 Views)
Abort delete event
114 Views, 1 Replies
03-23-2006 11:48 PM
Hi all.
It is necessary to interrupt removal of object
Database acadDB = HostApplicationServices.WorkingDatabase;
acadDB.ObjectErased += new ObjectErasedEventHandler(acadDB_ObjectErased);
void acadDB_ObjectErased(object sender, ObjectErasedEventArgs e)
// any actions
//e.Abort(); ????????
How to not admit removal of object
Member
detox
Message 2 of 2 (114 Views)
Re: Abort delete event
03-27-2006 12:54 AM in reply to: detox
Really, it is necessary to do so?
Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
doc.CommandWillStart += new CommandEventHandler(doc_CommandWillStart);
doc.CommandEnded += new CommandEventHandler(doc_CommandEnded);
DBObjectCollection dbObjects = new DBObjectCollection();
void doc_CommandWillStart(object sender, CommandEventArgs e)
switch (e.GlobalCommandName)
case "ERASE":
dbObjects.Clear();
break;
default:
break;
dbObjects.Add(e.DBObject);
void doc_CommandEnded(object sender, CommandEventArgs e)
case "ERASE":
RestoreObjects(dbObjects);
break;
default:
break;
void RestoreObjects(DBObjectCollection dbObjects)
Database db = HostApplicationServices.WorkingDatabase;
Transaction trans = db.TransactionManager.StartTransaction();
try
BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForWrite);
BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.PaperSpace], OpenMode.ForWrite);
foreach (DBObject item in dbObjects)
Entity restore = (Entity)item.Clone();
btr.AppendEntity(restore);
trans.AddNewlyCreatedDBObject(restore, true);
trans.Commit();
finally
trans.Dispose();
The most unpleasant, that thus is removed allocation....
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
