.NET
a way of the editing of the Group table
7 REPLIES 7
Message 1 of 8
NKCAUTOCAD01
1019 Views, 7 Replies
In AutoCAD.NET API, please tell me.
a way of the editing of the Group table of the collection object
Are there not the following operation samples?
 ①Crate of the new group
 ②The group name acquisition
 ③Element addition to the group
 ④Element deletion from the group
 ⑤The group acquisition from an element
 ⑥Deletion of the group
 ⑦I add the expansion data to the group,
and, please acquire it.
7 REPLIES 7
Message 2 of 8
khoa.ho
in reply to: NKCAUTOCAD01
Group collection is stored as a Group Dictionary on AutoCAD database (db.GroupDictionaryId). So it works the same way like any other dictionary-type objects (LayoutDictionary, ExtensionDictionary,...).
You can use the following code to write more code for your need:
public static void GroupAdd(Database db, string groupName, string groupDescription, bool groupSelected = true)
    using (Transaction trans = db.TransactionManager.StartTransaction())
        var groupDict = (DBDictionary)trans.GetObject(db.GroupDictionaryId, OpenMode.ForWrite);
        if (groupDict.Contains(groupName))
            return;
        var group = new Group(groupDescription, groupSelected);
        groupDict.SetAt(groupName, group);
        groupDict.DowngradeOpen();
        trans.AddNewlyCreatedDBObject(group, true);
        trans.Commit();
public static void GroupDelete(Database db, string groupName)
        if (!groupDict.Contains(groupName))
            return;
        var group = (DBObject)groupDict[groupName];
        group.Erase();
        trans.Commit();
-Khoa
Message 3 of 8
NKCAUTOCAD01
in reply to: khoa.ho
 Dear Mr. khoa.ho
Thank you very much for your precise advice.
Please tell me. approximately another two points
  1.Element addition to the group
  2.I add the expansion data to the group
Thanking you in advance.
Sincerely,
NKCAUTOCAD01(M.Tsukamoto)
Message 4 of 8
khoa.ho
Hi M.Tsukamoto,
Here is the basic code for group and a test command. You can expand more to suite your need.
Group is a dictionary entry with its name is the key. So the group name must be unique and not have spaces inside.
[CommandMethod("GroupNew")]
public static void GroupNew()
    Document doc = Application.DocumentManager.MdiActiveDocument;
    Editor ed = doc.Editor;
    Database db = doc.Database;
        // Get group name
        PromptResult resultString = ed.GetString("Specify new group name: ");
        string groupName = resultString.StringResult;
        if (string.IsNullOrEmpty(groupName))
            return;
        // Get group entities
        PromptSelectionResult selectionResult = ed.GetSelection();
        if (selectionResult.Status != PromptStatus.OK)
            return;
        if (selectionResult.Value != null)
            var objectIdCollection = new ObjectIdCollection(selectionResult.Value.GetObjectIds());
            GroupAddEntities(db, groupName, objectIdCollection);
        trans.Commit();
// Add a new empty group
public static Group GroupNew(Database db, string groupName, string groupDescription, bool groupSelected = true)
    try
        using (Transaction trans = db.TransactionManager.TopTransaction)
            var groupDict = (DBDictionary)trans.GetObject(db.GroupDictionaryId, OpenMode.ForRead);
                return (Group)groupDict[groupName];
            groupDict.UpgradeOpen();
            return group;
    catch (Exception ex)
        return null;
// Delete an existing group
            return;
        group.Erase();
// Add all entities in a collection to a group
public static void GroupAddEntities(Database db, string groupName, ObjectIdCollection entityIdCollection)
        Group group = groupDict.Contains(groupName)
            ? (Group)groupDict[groupName]
            : GroupNew(db, groupName, groupName);
        group.UpgradeOpen();
        foreach (ObjectId entityId in entityIdCollection)
            group.Append(entityId);
        group.DowngradeOpen();
// Add extension XData to a group
public static void GroupAddXData(Database db, string groupName, ResultBuffer xdata)
            return;
        var group = (Group)groupDict[groupName];
        group.XData = xdata;
 -Khoa
Message 5 of 8
NKCAUTOCAD01
Dear khoa.ho
Thank you very much for your accurate advice.
I thank for your advice heartily.
Yours sincerely,
NKCAUTOCAD01 (M.Tsukamoto)
Message 6 of 8
khoa.ho
Hi Tsukamoto,
You are very welcome. I hope you can add more functionalities to your code.
Here is another extra code to add an extension xrecord to a group, so you can use it as an enhancement over xdata.
// Add extension XRecord to a group
public static void GroupAddXRecord(Database db, string groupName, string xkey, ResultBuffer xdata)
            return;
        // Create a new extension dictionary of the group
        group.CreateExtensionDictionary();
        var extDictionary = (DBDictionary)trans.GetObject(group.ExtensionDictionary, OpenMode.ForWrite);
        var xrecord = new Xrecord
                Data = xdata
        extDictionary.SetAt(xkey, xrecord);
        extDictionary.DowngradeOpen();
        // Let the transaction know about the new xrecord
        trans.AddNewlyCreatedDBObject(xrecord, true);
-Khoa
Message 7 of 8
NKCAUTOCAD01
Dear khoa.ho
Thank you for repeated advice.
It was saved very much.
Yours sincerely,
Message 8 of 8
I know this is an older post, but I found it very usefull, but have a problem with the GroupAddEntities. I am still a novice programmer with .NET and usually stick to VB. I converted the above code to vb, but it breaks when there is an existing group already defined in the drawing. It is breaking at the "directcast" line. I used an automated conversion tool to convert to vb, so maybe it buggered up somehow. Anyway I have never used "directcast" before so I'm not sure what the issue is.
What I'm trying to do is an additional entities to an already existing group.
Public Shared Sub GroupAddEntities(db As Database, groupName As String, entityIdCollection As ObjectIdCollection)
        Using trans As Transaction = db.TransactionManager.TopTransaction
            Dim groupDict = DirectCast(trans.GetObject(db.GroupDictionaryId, OpenMode.ForRead), DBDictionary)
            Dim group As Group = If(groupDict.Contains(groupName), DirectCast(groupDict(groupName), Group), GroupNew(db, groupName, groupName))
            group.UpgradeOpen()
            For Each entityId As ObjectId In entityIdCollection
            Next
        End Using
    End Sub
 Any help would be greatly appreciated.
thanks
cj
”Boost
