.NET
Valued Contributor
NKCAUTOCAD01
Message 1 of 5 (260 Views)
a question in NETLOAD
260 Views, 4 Replies
12-16-2012 05:36 PM
Spoiler
It is a question in NETLOAD
In ACAD.LSP
(command "NETLOAD" "C: \\NKCCAD\\NET_DLL\\LAYERDISP.dll")
(command "NETLOAD" "C: \\NKCCAD\\NET_DLL\\PASTE.dll")
I put and test command practice by AutoCAD.
LAYERDISP.dll comes in Load, but PASTE.dll cannot play Load.
I have it experimentally if I do it, and the problem does not have NETLOAD alone.
Is plural NETLOAD not made?
Please advise it.
Hallex
Message 2 of 5 (237 Views)
Re: a question in NETLOAD
12-17-2012 01:23 AM in reply to: NKCAUTOCAD01
Try include full path of DLL include bin or Release folder
where this is stored
Moderator
Alexander.Rivilis
Message 3 of 5 (221 Views)
12-17-2012 06:40 AM in reply to: NKCAUTOCAD01
In ACAD.LSP
It is look like that the path-string has blank symbol after C: which is wrong. Also I recommend change all "\\" with "/".
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Mentor
gasty1001
Message 4 of 5 (214 Views)
12-17-2012 08:08 AM in reply to: Alexander.Rivilis
I agree with the space in the path string and the use of "/", but it doesn't explain the behavior of loading only the first dll, in that case no dll should be loaded, maybe  there is something else that is avoiding the load of the second one.
Gaston Nunez
Active Member
check-kay.wong
Message 5 of 5 (182 Views)
12-20-2012 01:30 PM in reply to: NKCAUTOCAD01
did you try to "manually" load your two dll see if it work?
did you try to load paste.dll before layerdisp.dll
Maybe your two dll have the same GUID? if is true, just change to GUID from your Visual Studio of one of your DLL and you won't to ask AutoCAD to load twice the same DLL.
by the way, i am just guessing....
