.NET
A couple of newbie Q's: Error message & loading Acad help.
3 REPLIES 3
395 Views, 3 Replies
Hi
It's my first day at transferring from vba to vb.net & struggling a bit (not helped by the fact all Autocad's own examples have errors in them). Hope you can help with these two:
1. I've loaded & built one of the example included in the object.arx download. I load & run the .dll once & it works as expected. If I edit & rebuild I get this error:
Unable to copy file "obj\Release\HelloWorld.dll" to "bin\HelloWorld.dll". The process cannot access the file 'bin\HelloWorld.dll' because it is being used by another process.
I get it on all the routines I tried. I've done a search online - nothing specific to AutoCAD but the general vb community doesn't appear to have much of a solution.
2. I'm using the Microsoft VB Express IDE. How do I load the offline help files for AutoCAD so when I highlight a word & press F1 it displays a help page for it? I've managed to do it for the general vb.net commands which use .msha files. Is there an equivalent for Acad?
Cheers
Dave F.
3 REPLIES 3
Alfred.NESWADBA
HI,
I assume you have another instance of ACAD.EXE running that has loaded this DLL. Maybe it's an invisible windows, look therefor in Windows-TaskManager if you find a process called ACAD.EXE in the list of processes.
Within the ObjectARX-kit there was an MSI that installs that help-support. But I don't use it and I don't know if it's working with the Express-version.
Good luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
@Alfred.NESWADBA wrote:
HI,
I checked & rebooted. Only one instance running. As I said, it runs fine first time & when I rebuild throws the error.
I'd already installed that file. They appear to be .HxS files & no idea how to integrate them, if in fact, there the correct ones.
Thanks, I think I'm goingto need it.:)
Alfred.NESWADBA
if you start VS in debug-mode, then you load your DLL into this AutoCAD instance using command _NETLOAD ... and you quit then AutoCAD ==> does VisualStudio come back to you, do you see that debuging-mode ended?
Other option: don't do a restart of your system. Look into the TaskManager if AutoCAD is running. Sometimes there are references build (or COM-activities) that may block AutoCAD from beeing quited in a clean way. It get's invisible, but it stays as a running process in the background. That is what I imagine as the source of your problem (otherwise you would be able to rebuild your solution).
- alfred -
Alfred NESWADBA
”Boost
