.NET
Active Contributor
dhorger
Message 11 of 21 (1,206 Views)
Re: 2011 Type Libraries Breaks 2010
05-07-2010 12:52 PM in reply to: dhorger
Got it! I was trying to load the COM elements instead of the dll's directly. Loading the dll's worked! Thanks, Norman!
*Tony Tanzillo
Message 12 of 21 (1,206 Views)
05-07-2010 03:53 PM in reply to: dhorger
Where did you get the SDK for 2011?
The SDK on the download page is for AutoCAD 2011.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2011
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6387769@discussion.autodesk.com...
Thanks for all your help, Norman. I downloaded the SDK for 2010 and added the
acax18enu.tlb and axdb18enu.tlb , but they still point to the AutoCAD 2011
dll's. I'm giving up for now and uninstalling 2011 so I can get back to work.
Thank you everyone for your help!
Active Contributor
dhorger
Message 13 of 21 (1,206 Views)
05-07-2010 03:56 PM in reply to: dhorger
Here it is: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=785550
You select which product to download for at the bottom of the page.
Valued Contributor
Martin60
Message 14 of 21 (1,176 Views)
07-26-2010 09:25 PM in reply to: norman.yuan
Thought I would add that I followed these directions with success.:smileyvery-happy:
Active Contributor
chrisshoemaker4224
Message 15 of 21 (1,105 Views)
08-24-2010 01:29 PM in reply to: norman.yuan
What happens when sheet sets get thrown into the mix? I've got AutoCAD 2010 and 2011 installed on the machine, and i've downloaded both the 2010 and 2011 SDK's. When I add a reference to "acsmcomponents18.tlb" in the 2010 SDK, it automatically adds a reference to Autodesk.AutoCAD.Interop.Common due to dependancies, however for some reason it insists on referencing the 2011 version "C:\Windows\assembly\GAC_MSIL\Autodesk.AutoCAD.Interop.Common\18.1.0.0...".  If i try to remove this reference and instead reference Autodesk.AutoCAD.Interop.Common from the 2010 SDK, I get compiler errors like this:
The project currently contains references to more than one version of Autodesk.AutoCAD.Interop.Common, a direct reference to version 18.0.0.0 and an indirect reference (through 'ACSMCOMPONENTS18Lib.IAcSmSheetSet.Sync') to version 18.1.0.0. Change the direct reference to use version 18.1.0.0 (or higher) of Autodesk.AutoCAD.Interop.Common.
 I'm hesitant that if i change the direct reference to the version in the 2011 SDK, the application will no longer run on AutoCAD 2011. Any ideas on how I could get this work on both 2010 and 2011 without compiling different versions (for both 32-bit and 64-bit!). Is this just some problem with the sheet set COM API?
-Chris
Valued Mentor
caddzone
Message 16 of 21 (1,102 Views)
08-24-2010 01:46 PM in reply to: chrisshoemaker4224
Did you try removing the reference to AXDBLib from your project?
I have a project that uses AcSmComponents18 and I was able
to remove the reference to AXDBLib and compile and run it
without errors.
AcadXTabs for AutoCAD
Supporting AutoCAD 2000-2011
Active Contributor
chrisshoemaker4224
Message 17 of 21 (1,099 Views)
08-24-2010 01:55 PM in reply to: caddzone
I would....unfortunately i'm making use of a method that requires a loaded AcadDatabase(ACSMCOMPONENTS18Lib.AcSmSheetSetClass.Sync(Autodesk.AutoCAD.Interop.Common.AcadDatabase) so even if i eliminated all other other code using ObectDBX i'd still need to keep the reference.
-Chris
Valued Mentor
Jeffrey_H
Message 18 of 21 (1,090 Views)
08-24-2010 02:57 PM in reply to: norman.yuan
It is supposed to be fixed with the update 1 for 2011
You can also find your answers @ TheSwamp
Active Contributor
chrisshoemaker4224
Message 19 of 21 (1,089 Views)
08-24-2010 02:59 PM in reply to: Jeffrey_H
What specifically is supposed to be fixed? I guess I still don't completely understand the problem....
Thanks everyone btw.
Valued Mentor
Jeffrey_H
Message 20 of 21 (1,084 Views)
08-24-2010 03:11 PM in reply to: chrisshoemaker4224
Quote from ADN
Unfortunately, the AutoCAD 2011 installer does not install the AutoCAD 2010 version (18.0.0.0) of the Autodesk.AutoCAD.Interop.dll. This has already been logged and is supposed to be remedied in the oncoming Update 1 for AutoCAD 2011.
